Results 1 to 15 of 25
03-11-2017, 08:00 AM #1Junior Member
- Mar 2017
- Rockport Ontario Canada
Merc 2.5 efi whistle at low idle.
Hey guys new to the site and was looking for some help. Last summer near the end of the season at low idle coming into the dock my motor started making a faint whistling sound , popped off the hood and almost sounded like it was coming from the flywheel. Motor runs perfectly fine other than this noise. Has anyone ever had this happen ? Or could give me an idea of what's up. Thanks.
03-11-2017, 11:27 AM #2
I had a 260 that would do that but never found the cause. Sounded like a bad vacuum leak on an old Chevy ! Mike
Cheaters never Win !!!
03-11-2017, 11:30 AM #3Junior Member
- Mar 2017
That's what it is a 260. Thanks for the reply mike. So your saying I have nothing to worry about then ?
03-11-2017, 11:36 AM #4
Prolly from the horn.
Michael J Giesler, 90 5.0 liked this post
03-11-2017, 01:14 PM #5
I was told it was from the idle holes in the butterfly being drilled oversize and a bored horn. It's the only one I've heard of till now that did it. I traded a stock 2001 200 for it and after not feeling comfortable with the noise I traded it for a Honda Rancher.
They are expensiveto rebuild , I would try a stock horn to see if it goes away. I would feel better if someone with knowledge would say its good to run !Cheaters never Win !!!
03-11-2017, 01:33 PM #6Junior Member
- Mar 2017
its weird because it started after a WOT run across the bay in front of the house ,At first it would whistle then I would shut the motor off and restart and it would go away. After a month or so of it doing this it would whistle consistently at low rpm and not stop. And the horn you had mentioned do the Efi's have that ? I've looked at pics and mine doesn't have that sticking out the front like I've seen in pictures. This is the first 2.5 I've owned so it's new to me.
03-11-2017, 01:34 PM #7Junior Member
- Mar 2017
Do the Efi's have a horn ?
03-11-2017, 01:45 PM #8Junior Member
- Mar 2017
And as far as I know the motor is stock other than the lower unit. Nothing has been bored or touched. I don't I'm just hoping I can diagnose the problem and have it fixed because I love the power of this motor. And the sound
03-11-2017, 02:45 PM #9
If its a 260 it should either have a horn or SVS front. Is this an aluminum colored motor ?
03-11-2017, 02:55 PM #10
You say it seems to be coming from around the flywheel, Id be checking the oil feed to the top bearing.
Peter Thomas
WillySteve liked this post
03-11-2017, 03:05 PM #11Junior Member
- Mar 2017
It seams that way but the motor is so loud at idle it's hard to make an accurate determination. Thanks for your opinion man I'll look into it
03-11-2017, 06:55 PM #12
Early, '84ish oval port 2.5 efi's had an updraft horn, still with the single butterfly!
WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
03-11-2017, 07:42 PM #13
WillySteve, RIVERRUMMER 70 liked this post
03-11-2017, 08:25 PM #14
Ooops!!
03-12-2017, 03:24 PM #155000 RPM
- Nov 2013
- palatka fl
- 117
same prob
mx722 ihave same problem that just showed up,did head job still there. mine is 1993 carb 2.5 off shore fishin mtr. this is strange ,i seem to think maybe its a bad exaust plate gasket, some time with all motors you have to start a tear down and look for bad gaskets,my motor 1993 just started this after 24 years of service,not bad huh,i wanted to chime in here and share my prob,i will post later with results as i find it . cheers.
Mercury Tech: Throttle blade whistle on a promax/ laser injected motor?
By silverbullet02 in forum Technical DiscussionReplies: 4Last Post: 03-28-2015, 03:00 PM -
Canadian footballers dont stop at the whistle
By John S in forum The Scream And Fly LoungeReplies: 1Last Post: 11-28-2011, 10:42 PM -
HEY G-TRAIN.....start warmin up yur WHISTLE...yur bout ready to leave the STATION!
By yellowallison in forum General Boating DiscussionReplies: 30Last Post: 03-31-2010, 07:21 PM -
Carbed Merc 200 idle and idle timing adjustment
By Mr. Demeanor in forum Technical DiscussionReplies: 2Last Post: 02-28-2006, 06:21 PM -
Idle Speed/ Idle Timing - 1997 Merc Promax 225
By HST Madman in forum Technical DiscussionReplies: 0Last Post: 09-16-2004, 08:21 PM
