Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Single Ram Trim
    TX......somewhere?
    here's one....
    http://www.boats.net/parts/search/Me...nce/parts.html
    there are a few others but they are all 'bout tha same...
    newer ones may be stainless but know for sure 2000 back were rust prone steel........
  2. #17
    Jul 2012
    Lufkin, Texas
    Only other real difference is those have the small tiller and no plastic side wear plates . You can machine the pockets and install them and the big tiller will go right in .
    In my eyes , the late model 3.0L tiller arm / pin is the best way to go . You have to separate the two , turn the arm down to one inch tall , clip the steering stop nub off and shorten the pin and then put it back together .
    Any pics of this procedure? I'm interested!
    Josh Peterson
  3. #18
    Are you doing a 15" or a 20" ?
    For 15" do a search , I know I have posted dozens of pictures in various threads ..
  4. #19
    Mar 2010
    houston, tx
    "swivel bracket" is right.. ya not old enough ta no that "saddle" (1960's slang) is same thing...... sorry.
    think 90.5 jus went thru this... he had one of each.. said he found some subtle differences but didn't say what?
    I only have a 15" offshore to compare it to not a 20"'but the clamp itself "looked " slightly different, in the way it was made.
    Will have to look again closer, but my 80's model or even 70's maybe has a different anode than his under the cylinder. Heck it might not even be stock.
    Number of the clamp is 5465101
  5. #20
    Jul 2012
    Lufkin, Texas
    here's one....
    Thanks for the link, after a few minutes comparing, transom bracket, swivel, tilt tube, etc. are all the same part numbers between race and bass. Myth busted.
    Josh Peterson
  6. Likes 90 5.0 liked this post
  7. #21
    Jul 2012
    Lufkin, Texas
    Was planning on doing a 20, but I just to stir the pot a little more, I have a cut down old 2 ram clamp that I may end up using. Not quite 15, maybe 15-7/8" or so. If I bolt it all the way down on the transom it looks like it will put the centerline of the prop shaft pretty close to dead even with the bottom of the pad...
    I tried searching earlier and came up empty handed, will keep trying...
    Josh Peterson
  8. #22
    TX......somewhere?
    we used one of those loooong time ago... tha brackets made a change in '93/'94 some where... maybe when big tiller and/or tha drag came out!
    and your right 'bout clearance on that cowl pan............
  9. Thanks nitro_rat thanked for this post
    Likes nitro_rat liked this post
  10. #23
    Jul 2012
    Lufkin, Texas
    Yeah, the parts I checked were late 80's, still had the skinny tiller. I'll try to look up the fat tiller stuff tomorrow!
    Josh Peterson
  11. #24
    Jul 2002
    FT WORTH, TEXAS
    you will find a lot of myths in Mercury definitions Ive discovered some really cool stuff in the last few decades that saved me lots of time and BS when it comes to mercury im nearing the 400 Merc v6 motor rebuild number i may or may not get there at 71
  12. Likes nitro_rat liked this post
  1. Single ram trim and trim pump
    By phase3looper in forum Misc. Parts and Accessories
    Last Post: 08-20-2013, 08:56 PM
  2. removing trim ram in a 84 200 merc, single ram trim.....
    By syclone01 in forum Technical Discussion
    Last Post: 02-27-2011, 11:36 PM
