Results 1 to 15 of 20
    Baton Rouge, La
    1998 pro max drop on $3700
    Posting for a friend. David 225-773-7343. Pro Max 225
    About 75 hours on a bass boat since new .015 pistons , rings,metal cage bearings , reeds and bore. 16 amp electrical system. One hole needed to be bored so did all 6 so.they are all fresh. . Much more detailed add with pics on Byuboyz with complete compression and leak down numbers. 147 lbs compression clean and ready to go. Mike at Greenwell Springs Marine did the work. I can text pictures if you can't get on Byuboyz. Mike Six 0 1 -551 1350
    Attached Thumbnails Attached Thumbnails 0217171248.jpg   0217171252.jpg   0217171249.jpg
    Cheaters never Win !!!
    appleton,Wi
    hp ?
    Boatless but want a Progression, Super, Tuff, Activator, Scorpion, ish !!!
    Baton Rouge, La
    This is a stock 225. I have heard 240. Mike
    Baton Rouge, La
    Added pics. 145 -147 lbs compression. 3% leak down on all but 3&4 which were 4%
    75 hrs on stator rectifier trigger and packs.
    Baton Rouge, La
    Still for sale. Its also for sale locally. Clean and well maintained. Put it on and go fast ! Mike
    Mar 2011
    Virginia
    Looks like it was converted to 16 amp charging system. Thats not a 40 amp flywheel in the pics. What pistons?
    Go Time
    26 Regulator twin 250 EFI
    Baton Rouge, La
    Yes it is 16 amp electrical. Added to the first post. Thanks.
    Oct 2005
    Key Largo, FL
    Is shipping available?
    Baton Rouge, La
    Yes ! Shipping is available. Post your zip and I.will get a quote. Mike
    Oct 2005
    Key Largo, FL
    Thanks. 33037 to a business with a loading dock and forklift.
    Baton Rouge, La
    I will let you know. Mike
  12. #12
    Baton Rouge, La
    Looks like $300 on southeast. You pay 200 he'll pay 100. Mike
  13. #13
    Oct 2005
    Key Largo, FL
    Thanks Mike! I'll call you tomorrow.
  14. #14
    Baton Rouge, La
    You can call me if you like but David is the deal maker. I'm in a bad cell area so text first so I can get where the phone will work. Mike
  15. #15
    Baton Rouge, La
    Needs to go, 260 on the way. Mike
  1. 1998 225 Promax Drop-on
    By Deville in forum Outboard Engines
    Last Post: 07-17-2016, 07:21 PM
  2. 1998 Mercury 3.0L 225 Carb Drop On Powerhead
    By M.CHAPMAN in forum Outboard Engines
    Last Post: 12-01-2014, 10:02 AM
  3. 1998 225 ProMax power-head (drop-on)
    By bware in forum Outboard Engines
    Last Post: 09-11-2014, 08:42 AM
  4. Nothing like 3700 HP
    By Powerplay25 in forum General Boating Discussion
    Last Post: 07-28-2009, 12:22 PM
  5. OMC Tech: Johnson 150 1998 WOT RPM drop
    By luhrern in forum Technical Discussion
    Last Post: 07-15-2009, 04:09 PM
