Results 1 to 15 of 20
    Nov 2001
    Buford, Georgia
    Made some progress on my motor today
    Slow here at work and I had all of the stuff here, so I prepped my midsection and shot a coat of DP40LF. It's really slow today, so to help with some of the boredom, and to go along with all of the powerhead pics I took some of the mid after I got done shooting the primer.
    Take a look
    --Brian Chandler--
    Sunshine Syndicate Wiseguy.
    Nov 2001
    Buford, Georgia
    You didn't think I was just gonna post one did ya?
    --Brian Chandler--
    Nov 2001
    Buford, Georgia
    last one. Next time you see it, it will be black.
    --Brian Chandler--
    Georgia
    7 Thread(s)
    Flounder, what'd you do to it before the primer? Did you take it all the way down?
    Nov 2001
    Buford, Georgia
    Yeah, like a dumbass. Hell I should have quit when I realized that the Merc stuff stuck pretty good. The majority of the mid was stripped to bare metal. There's a couple of places that just got a good scuffing. You can't tell where the painted places are vs the bare places now that the primer is on, which is one of the things I was worried about.
    --Brian Chandler--
    Georgia
    7 Thread(s)
    Well, that answers the next question. I've tried bead blasting em (that stuff Merc uses is too hard) sand blasting (leaves too course a finish in the alum. that takes too much priming/sanding) and chemical stripping with aircraft stripper (stuff is too tough to do easily that way too)
    I was hoping you'd found an easy way.
    Nov 2001
    Buford, Georgia
    Seems like we're answering each other's questions. I'd considered media blasting (sand, glass or otherwise) but never considered the resulting surface finish. I used chemical strippers and all they did was remove the layers of spray paint that had been applied in the past. It was at this point that I should have realized how tough the Merc stuff is and just feathered the chips and scratches and proceeded from there. But noooooo I had to break out the 90 degree die grinder and a handful of 2" and 3" 3M Roloc scotchbrite discs. I will admit though, there was a fair amount of satisfaction as the black paint and green primer came off. I'd won....okay well sort of. As I was consuming scotchbrite discs it occurred to me that if the coating is that strong, it would make just as good a substrate as the bare aluminum. I finished doing the large surfaces, then DA'd with 80 and then 320 cleaned up the nooks and crannys and let the primer fly. I used the DP401 catalyst for the primer. It requires a 30 minute induction period before shooting, but I've heard on very good authority that it bites into aluminum rather well. Better than DP40LF with DP402 catalyst.
    --Brian Chandler--
    Jun 2001
    Thunder Bay, Ontario ,Canada
    Did you try glass bead? I'd think that would work well.
    Hydro Burke
    AE-21
    330 HP 2.5 "Monster Marles" Merc
    Seebold F1 race boat
    May 2001
    In the Hills
    man i tell ya been there done that and that merc paint is some tough stuff!!
    even using proffessional grade aircraft stripper at the helicopter shop i worked at for 7 years (worked a hell of alot faster than the over the counter aircraft stripper) but was still a beoch
    i now just DA the layers of spray bomb off and use the merc paint as a base to prime to
    Sunshine Syndicate Facebook link...
    https://www.facebook.com/pages/Sunsh...ref=ts&fref=ts
    Nov 2002
    Orlando Fla
    The stuff looks great
    the project looks like it is coming along fine, I have heard of lots of people putting in long hours on projects preparing for the RBR... as we speek my TABASCO is at Waynes Auto Marine getting a 5 hour old 280,,, hell I hope I will have it ready for the RBR??? lot of luck on those projects
    Get It Wet And Go Fast.
    Thank you for being so nice
    Baton Rouge, La
    don't blast
    Ask Buckwild about that one. It seemed like a good idea to freshen up that 2.4 offshore. Every void was exposed and showed up as a black spots in that beautiful Mariner grey.
    The Merc paint is on good just like pounder did feather and make sure of compatibility.
    Cheaters never Win !!!
  12. #12
    Nov 2001
    Buford, Georgia
    Laid the black PPG OmniCV down on it Friday afternoon. All was great until I threw down a second wet coat. Got a couple of sags on one side that I'm gonna have to sand down with 400 mask of that side and squirt it again. I haven't looked at it since I walked out of the shop Friday to go home. Kinda anxious to get back to it.
    Skip and I were talking last night and rummaging through the parts I've accumulated and it looks like everything is either in my posession, in Skip's garage, or on it's way. Powerhead assembly is right around the corner.
    I doubt I'll have all of the rigging issues dealt with in the manner I'd like before Palatka, so that's out. I've got some fiberglass work and painting to do also. I'll be doing the local thing probably until fall when the Keys thing and the End of Summer thing hit.
    --Brian Chandler--
  13. #13
    May 2001
    In the Hills
    i wont make palatka either, too much practicing for the rumble band to do, and want to get moving on pounders motor soon too
  14. #14
    St.Cloud Fl
    BROTHER POUNDER
    DO YOU WANT THOSE JACK PLATE EXTENSIONS WE TOOK OFF THE PUMPKIN AT BIG D'S HOUSE. GOT MY NEW BOAT IT ALREADY HAS A JACK PLATE. SO I DONT NEED THEM ANYMORE. I GOT ME SOME TRAING WHEELS OR AS BRAD CALLS THEM A PEANUT WAGON.
  15. #15
    Nov 2001
    Buford, Georgia
    hey if you don't need them anymore it would sure save me from having to make new ones. I'll take em!!
    Saw the pics of your new ride. Congratulations!!
    --Brian Chandler--
