Results 1 to 10 of 10
    May 2009
    Myrtle Beach
    Reed cage porting advice please. (pics)
    I know I am probably wasting my time or even ruining these cages. I could get a 7 pedal front half but I want to work with what I have if I can. I pretty much centered and traced the CCM reeds and opened the openings trying to match the square reeds versus the factory teardrop shape. I still need to clean them up with a file and lap them but I'm only doing one cage before I seek advice and ruin all six. Motor is a 2.4 200 with 6 steel sleeves. Heads shaved, cut front half, block decked and .030" cut off the top of each piston to match the deck. No exhaust work. Worthwhile to mess with the cages? Thanks, Scott
  2. Likes Keaten liked this post
    Apr 2016
    Victoria bc canada
    Following... also curious...
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
    All that stuff will help the midrange so it should pull harder but do little (if anything) for top end.
    An engine is basically an air pump, the more you put through it, the more horsepower. The biggest gains are in cylinder/piston porting, then you open up intake and exhaust to match the increased flow capacity. Increasing flow in a single area will only provide modest gains.
  5. Likes rock, Dave Strong, rgsauger liked this post
    GA
    Just wondering, why didn't you go with the square 4 petal?
    Sep 2006
    Key Largo, Fl
    Looks like you're off to a good start,it will help.If you have a Harbor Freight store nearby go get their air file...helps speed things up,Chris
    Remember seeing the comparison thread, modified CCM cages and reeds made the most hp anyone have the link?
    May 2002
    Lake Havasu City AZ
    I made a plate to bolt my Erude cages to and put them on a mill and used an 1/8 end mill. Digital readout made them all exactly the same.
  10. Likes stoker2001 liked this post
    Sep 2015
    Twin Cities, Minnesota
    I don't have DRO. I should get it though. would have to go handle revs. 1,2,3,4. 1,2,3. 1,2,3,4. 1,2,3. Not as fun.
    CHAIN O LAKES, IL
    Quote Originally Posted by krazymaan View Post
    i don't have dro. I should get it though. Would have to go handle revs. 1,2,3,4. 1,2,3. 1,2,3,4. 1,2,3. Not as fun.
    lol....goot one.
    what was the outcome ? did this give good results that were noticeable ?
  14. Thanks Mark75H thanked for this post
  1. Who has seen a reed cage like this
    By Ripnfool in forum Technical Discussion
    Last Post: 09-17-2009, 09:55 AM
  2. reed cage ?
    By 1fastfriend in forum Technical Discussion
    Last Post: 03-05-2004, 02:07 PM
