Results 691 to 705 of 801
06-27-2003, 01:33 PM #691
Not at The Romp
And the ones that do are usually highly modified. I've never seen it.
David
06-27-2003, 02:15 PM #692
Easy to work on
I'll give you that, and parts are abundant. I just see alot of 2.5 guys with their motors in peices alot.
2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-27-2003, 02:24 PM #6937000 RPM
- Toronto Canada
- 2,155
I am with David on this one, 2.5's are fairly stong motors.
My challenger is running a best of 78.9 on GPS now and that is with a 2.5 carb 100% stock........it will break 80 with a little more setup........then I am bolting on a 280.
RTHe who laughs last, thinks slowest.
06-27-2003, 02:39 PM #694
Sure
But what are you turning to only get high 70s, 7000+? I just feel bad making a motor work so hard.
06-27-2003, 02:43 PM #6957000 RPM
- Toronto Canada
- 2,155
72-300 actually and it seems to like it, my poor STV all ran 9000 +
06-27-2003, 02:45 PM #696
3 Liters
Well the ones I know of usually try to saw themselves in half when they blow and if you ain't got a warrantee......u iz screwed. Lots of rotating mass there.
David
06-27-2003, 03:01 PM #697
Yep
If only OMC (Bombardier) made a 300+ V6
I hope my Merc stays together awhile.2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-27-2003, 03:03 PM #6987000 RPM
- Toronto Canada
- 2,155
Yamaha is...........that is my next motor!!!!!!!!
06-27-2003, 03:05 PM #699
Oh yea
What's up with that, Yamaha is supposed to be unveiling one right? Anyone got details?
I'd buy one for sure.2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-27-2003, 03:07 PM #7007000 RPM
- Toronto Canada
- 2,155
I read some stuff a few weeks back , you can get one in the fall
300hp, under 500lbs, and 87 oct fuel and direct injected.......cant beat that.
06-27-2003, 03:13 PM #701
2.5 V-6 merc
Is probably one of the most refined designs out there, almost 30 years of production and refinement and the current 280 has just about every good idea mercury has thrown at it. Am I afraid of it coming appart? not really, as long as I leave it stock and prop it to allow it to turn up like it was made to do.
Do they come apart, sure they do, what dosen't, but like Fly said they are usually highly modified or as I have seen, improperly lubricated, bad fuel, or over propped (lugging the motor).
We have all seen many broken outboards, but there are also allot of very dependable 2.4's and 2.5's out there so it will be interesting to see how well the 300's hold up over time.
BTW, thanks for the compliment at100plus22' Activator w/ 250xs Merc Opti, back home again
06-27-2003, 03:40 PM #702
Yamaha
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOObOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Make sure it has the wing on the cowl blaahahahahahahaha
06-27-2003, 10:58 PM #703
Yammy
Well, their golf carts hold up pretty good
06-27-2003, 11:51 PM #704Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Early V6's
I'm calling them early, but whatever you call them they are made in the USA. Remeber that place where you live, work, and pay bills? I kinda think of them as small block chevys, just getting older and better, spinning away. 3.0s are good to, like BBCs more cid more low end power.. If a chevy 350 can turn up with it's big stroke why can't a 3.0? With out BLOWING to peaces that is? Boy this thread goes on
06-28-2003, 06:05 AM #705
2.5 Hi perf engines
First of all they squeez a lot of power out of a small package. One of the reasons IM a big fan of them.
IM not however a fan of hot rodding them all that much especially by raizing compression.
Secterts to keeping a 2.5 alive.
Keep stock compression or under 140 lbs
Use 1/2 fuel line. 5/16 return
Run good 93 octaine with synthetic oil
Run 2 fuel pumps with a slosh tank
Ballence internals
Top pin pistons.
Replace electronics every 3 or 4 seasons.
(hard part) Keep rpm under 8,000 but over 7,000 when maxed out with light load.
After years of broken engines and dealing with morons who say they they fix them this is what I learned from this board and doing things myself.
3 seasons on the back of my boat and my engine has never failed. And I use it for all its worth. 2 runs alone where 70 miles with one stop in between at full throttle.
If you cant rebuild a 2.5 or your best friend cant either I would strongly suggest my recipe or run a different engine.
Oyeah I have a 280 long block for sale. ballenced and ready to assemble. $4000 with MAD EFI flywheel. Just renicked.
