Results 1 to 2 of 2
01-29-2017, 04:07 PM #16000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Late 1995 mercury 2.5 260 power head minus ecu
1995 mercury 2.5 260 power head minus ecu.
The ecu that is on the motor in the pictures I'm not sure if it works. I was told it was good but never tested it for my self. I will include the ecu will the sale but can't say it works. It is a 11350-a38
Motor is all nic. No steel sleeves. No welding. Never been plated or blown up. 98 percent fresh water use.
This motor has top pinned pistons by ( John Marles) brand new mercury gold rings, new bearings, new head gaskets, new spark plugs, new rod bolts, weight matches 141 rods, 35cc heads, Lake cut on the exhaust chest, slight rod notch work. Horn and reed plate are stock. Chris Carson reeds. Brucato just flowed the injectors. ( no fuel has been through them yet) 39 psi regulator. Factory flywheel and electrics.
The motor has not left my bedroom since it was built. It has not been turned over or started or gas in it. So I don't have compression or leak down number but can get them. Just hard since I have to bring it to my shop
I bought this motor from a member off here and went through it myself. I was keeping it for a spare but things changed and I'm going a different route.
I can text , email pictures. Katoomrider99@aol.com or my cell 860 202 4683
. $4200 obo plus shipping or local pickup I'm located in ct.Last edited by superboattwin250; 01-29-2017 at 08:23 PM. Reason: More info added
01-29-2017, 07:07 PM #26000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Will trade for newer style 12 inch mid.
Wanted: Power head for a 1995 3.0 225 efi
By knarloid in forum Engines WantedReplies: 5Last Post: 10-23-2016, 07:46 PM -
Mercury 2.4 DROP-ON rebuilt power-head (late '80's 200HP) FS
By centuryclub1990 in forum Outboard EnginesReplies: 7Last Post: 12-02-2015, 12:13 AM -
Late 80 2.0 liter Merc 135 power head part out
By superboattwin250 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 01-30-2015, 08:58 AM
