Results 1 to 15 of 23
Thread: 2008 Suburban cam replacement
01-25-2017, 12:50 PM #1
I'm ordering everything now to replace the cam and lifters and do an AFM delete. It is a 5.3 litre engine. Is there enough room in front of the engine to remove the cam without removing the AC condenser? Or am I better off removing the engine?
01-25-2017, 01:14 PM #2Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Pull the mota
flabum1017 thanked for this post
02-04-2017, 12:53 AM #3
There is enough room, we don't pull motors when doing. Pretty sure the guys aren't pulling the condenser. If lifter has already failed recommend replacing oil pump or at least pull down to inspect. Have seen pieces of debris get in pressure valve and stick. And replace pick up tube o-ring.
flabum1017 thanked for this postCapt.Insane-o liked this post
02-04-2017, 07:46 AM #4
The oil pressure had dropped to 20 PSI at idle (40 at 2000 rpm) when the lifter began to make real noise. I had already planned on doing the oil pump and drop the pan and pull a couple rod caps and main caps to inspect for debris. I'll have an AC shop depressurize the system and cap off the lines and condenser just in case I have to get the condenser out.. Thanks for the replies ....................
02-04-2017, 09:47 AM #5
Just verified that there is enough room without removing condenser.
02-04-2017, 11:50 AM #6
cool, thanks, saves the trouble of pulling the motor, once all the accessories are off the front of the motor, I can stand in front of it to do the cam and lifters.
02-04-2017, 12:29 PM #7
How much do you think this will cost to do?
LC9 should be the non-AFM 5.3L motor?
http://www.genuinegmparts.com/powertrain-parts/engines
02-04-2017, 12:53 PM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Pull the motor , you never know what you'll find and its easier to set up on a stand.
02-04-2017, 12:59 PM #9
I got the cam, lifters and gaskets for $500 and the oil pump and head bolts and misc parts will be another 300. Will send the heads out to be freshened up and probably will do the rear seal if I pull the motor. I'll probably have a grand in parts, a couple hundred in the heads and my labor.
David - WI thanked for this post
02-04-2017, 03:19 PM #105000 RPM
- Jan 2017
- Albany NY
- 397
- 28
- 20
- 98
- 125
ive pulled the motor out of a 2500hd with an 8.1 without removing the AC condenser, I just turned it 90 degrees out of the way.
02-04-2017, 05:03 PM #11
I've decide to go ahead and remove the engine, may as well do the rear main seal too. Right now I'm at about $800 with all the parts. I have to send the computer out for programming since I can't find anyone down here who comes recommended (weird for Ft Lauderdale). That will be another $100 or so. Then, since I had rotator cuff surgery back in December, will have to hire a helper for another couple hundred.....Still far less than the $4,000 - $7,000 estimate from around town. How the hell can Chevy think your'e gonna put that kind of money into 9 - 10 year old vehicle; you would think those engines would be more affordable by now.
02-05-2017, 10:27 PM #12
Rock Auto has a rebuilt long block for $1200, so if I get this thing out and apart and find too much damage, I'll just order the long block and swap everything over.
David - WI liked this post
02-11-2017, 06:58 PM #13
Well, got the motor out, took 8 hours. Not bad considering I'm at 7 weeks past rotator cuff surgery and all my help bailed so I had to do it by myself. Found the noise maker, was one of the non-afm lifters. Looks like something got in the roller and it skidded, Will have to tear it the rest of the way down and see if I'm in it for bearings too.......
FMP liked this post
02-11-2017, 07:47 PM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That lifter bore may need a sleeve, decided to keep the hood on .
02-11-2017, 10:07 PM #15
Didn't get a good look at the bore yet, was getting late and I was very sore from the day. Will get a good look at it tomorrow. I figure I'll pop a couple rod caps and main caps to see if there's any bearing damage. Will put new cam bearings for sure. What are you using for cam lube on these roller lifters? I always have use STP engine treatment mixed with oil, seems to stay on until fire up....
Left the hood on because I had to remove the intake to get to the top transmission bolts and the intake being off gave me enough room for the cherry picker to get to it."One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
'08 Suburban noisy lifters
By flabum1017 in forum Tow Vehicles and TrailersReplies: 27Last Post: 11-10-2019, 12:12 PM -
2003 suburban LT
By YELLOWSS in forum The Scream And Fly LoungeReplies: 4Last Post: 12-22-2007, 11:44 PM -
97 Suburban - Turning off auto headlights
By SAMMYBOY in forum Tow Vehicles and TrailersReplies: 13Last Post: 08-04-2006, 11:29 PM -
1989 GMC Suburban $2900 firm
By PIT BULL in forum Tow Vehicles and TrailersReplies: 0Last Post: 09-04-2001, 09:53 PM
