Results 16 to 30 of 34
Thread: Cmc actuator rebuild..
01-30-2019, 05:43 PM #16
Anytime Slimm! Just let me know when you need some.
1981 Hydrostream Vandal W/ evinrude 16" gt150
02-04-2019, 12:27 PM #17
A place called Buck´s Electric in Texarkana used to rebuild jackplate and trim engines. I used them once, many years ago.
Might be worth checking if they are still around...Markus' Performance Boating Links:
02-05-2019, 09:14 AM #18
Thank you Markus, appreciate the info.
SlimmHire the handicapped, we're fun to watch
03-12-2019, 06:55 AM #19New Member
- Mar 2019
- Ga
I need some brushes
05-01-2020, 12:58 PM #20
Mine is a bit "variable" this spring for whatever reason. Its not steady speed up down so I too would like to do some brushes. Does anyone know what ones to start with to whittle them down or do we have a supplier for these now? I wonder if prestolite brushes would work?
05-02-2020, 12:25 PM #21
I had a few sets made and I have them somewhere but ill have to hunt them down
05-03-2020, 08:31 PM #22
I hunted them down if anyone's looking. I have 3 sets left. $30 a set plus shipping.
06-10-2020, 01:40 PM #23New Member
- Sep 2006
Do you have any sets left?
06-10-2020, 01:53 PM #24
I do have a few sets left
06-10-2020, 02:22 PM #25New Member
- Sep 2006
08-02-2020, 07:18 PM #26New Member
- Aug 2020
- Orlando fl
7050 actuator
Hey guys! It sounds like you guys have already taken these things apart and rebuilt them. I'm in the process now. Mine was leaking fluid pretty badly. Tomorrow I plan to go find some replacement seals from local rubber/hose company. But I wanted to ask you, I noticed when I took this apart that there were 4 small stand offs with springs. Two of them had small steel balls. But only two of them had o-rings on the top of them. Is this normal that two of them didn't have o-rings??
08-03-2020, 06:57 PM #27
Yes, no O rings there and mine did not have a gasket to seal the end plate, it is just a precise fit. I would replace the bypass screw on the external/bottom while you are ordering parts from T&R. The old style valve screw has a head that pops off and you will lose all fluid.
Mine is 22 years old and the release valve slotted head popping off is its only failure.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
08-04-2020, 07:45 AM #28New Member
- Aug 2020
- Orlando fl
Thanks
Thanks for the update. So that's what that is? I wonder how tight you are supposed to make that release bolt. I snugged it as hard as I could without stripping. Maybe I should back it off a bit. That was probably my issue to begin with, it didn't release pressure where it was supposed to.
I'm posting a video to youtube https://youtu.be/FrcCrsA4ySM It's nothing special but maybe it will help people in the future since I couldn't find ANY pictures of this thing.
08-04-2020, 07:51 PM #29
The head popped off of mine when I lowered it to a hard down position. The pressure is high enough to pop the head off the release/bypass.
Allison GSE 300XS
11-01-2020, 06:44 PM #30New Member
- Sep 2020
- TN
Do you have any sets of the brushes left?
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM -
Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 10-06-2010, 06:39 AM -
Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
By rickyo in forum Technical DiscussionReplies: 5Last Post: 06-05-2010, 04:08 PM
