Results 1 to 15 of 40
Thread: V4 omc gearcase hop ups
01-16-2017, 05:35 PM #1Member
- Jun 2011
- ontario
- 60
I'm building a 14" cross flow for my mirage cheetah .pictures are on hpbcanada if you want to see it. I'm looking for gearcase help for this project. Does anyone make a billet bearing carrier for this motor or a way to convert it to 15 spline. Does anyone have any other suggestions for some gearcase mods . Monty will be cutting Drive shaft and I am am installing a modified bobs cone.
01-16-2017, 05:51 PM #25000 RPM
- Aug 2002
- florida
- 804
- 13
The early V6 prop shaft fits in the gear case giving you a 15 spline shaft really opens up the possibilities as long as you use a 14 inch diameter or smaller prop
01-16-2017, 05:52 PM #35000 RPM
- Aug 2002
- florida
- 804
- 13
Pretty sure a 14 & A Quarter inch prop will fit but it's tight
01-16-2017, 05:54 PM #45000 RPM
- Aug 2002
- florida
- 804
- 13
The nose cone to use on Netgear case is a bombs made for an inline 6
01-16-2017, 06:01 PM #5Member
- Jun 2011
- ontario
- 60
Do you know part number of prop shaft or what years of v6?
01-16-2017, 06:54 PM #6
On my old 140 looper I went with a v-6 gear case so I had the 1:86 gearing.
01-18-2017, 02:01 AM #75000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
Find a 1973 135hp gear set. Its 1.86:1. Not 2:1. Lets you spin lower pitch props faster. Where the 13 spline usually runs out of high pitch props. If you go 15 spline. The prop bodies are larger than the case unless you run a small hub prop.
Mark75H liked this post
01-20-2017, 08:56 PM #8Member
- Jun 2011
- ontario
- 60
I would love to switch it to 1.86 . I will keep my eye out for a donor case. Still would like to do a 15 spline conversion . Trying to source a early 80s v6 shaft this weekend for fitting. Does anyone make a billet carrier possibly double bearing for a 4" case?
01-20-2017, 11:54 PM #97000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
The 73-76 135 and 77 140 gearset is 13:25 or 1.92:1, not 1.86:1. To use in a mechanical shift case you have to machine/remove the drive for the hydraulic shift assist from the front of the forward gear.
I believe any V6 propshaft requires machining to fit the V4 carrier bearings and gears. Diameter is larger. None are just bolt in.
olboatman thanked for this postFreddie Webb, 1BadAction liked this post
01-21-2017, 07:46 AM #10"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
01-22-2017, 04:43 PM #11
01-22-2017, 05:04 PM #127000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
I assumed this was about using the V4 gears inside the V4 case but with 15 spline V6 propshaft. I have two of those from the early '80s and both use propshafts made or modified by Land and Sea and 13:26 gears.
A few folks have posted over the years about using an early V6 shaft but I've never seen how that could work without significant machine work.
Don't recall hearing of anyone modifying V6 gears to fit inside the V4 case.
01-22-2017, 05:33 PM #13
you're right on the V6 gears in V4 case.
I was referring to the early V4 gears 13:25 with pump drive on fwd gear. To get these gears in the newer style case without oil pump( I think '77 & up) there are more modifications needed . Removing the pump drive on the gears is one of them.
Bruss
01-22-2017, 06:30 PM #147000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
OK and agreed, I see that was what you meant after reading more carefully.
Although V6 gears in the little V4 case would be pretty cool.
brussrude liked this post
01-23-2017, 11:01 PM #15
I am running two of them now only 1 year shaft that works 77 175-200 only other mods required is bore reverse gear and install v6 same yr Berrings in rear of carrier
13 ft allison 75 omc
14 ft Allison
15 ft allison molds
17 ft tin fisher-marine 3cyl. omc
17' Allison ski boat
Grand Sport w/etec
Freddie Webb liked this post
4,88 diameter gearcase vs 5,44 diameter gearcase speed difference?
By Toffen in forum Props, Setup, and RiggingReplies: 0Last Post: 12-26-2012, 06:46 PM -
Mercury Tech: 2.5 gearcase on a 3.0L
By GPRACING in forum Technical DiscussionReplies: 2Last Post: 03-28-2010, 05:17 PM -
Mercury Tech: 3.0 gearcase ?????
By Promax1R in forum Technical DiscussionReplies: 1Last Post: 03-04-2010, 02:13 PM
