Results 76 to 90 of 215
Thread: 1971 Donzi Classic 18 power....
01-24-2017, 08:41 AM #76Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
01-24-2017, 09:27 AM #775000 RPM
- Jan 2017
- Waterford Michigan
- 104
- 17
It could be, but according to Mercruiser, it's 14-1/4" for a 15 degree transom with the Bravo One. Alpha and B3 are the same nominal position, but do tolerate different upward ranges
01-24-2017, 10:09 AM #78
I'll see if i can put you in touch with a guy that has a -2 imco.
Classic18 thanked for this post
01-27-2017, 01:36 PM #79
@FUJIMO has given great advice so far. Maybe I missed it but what is your budget? That can dictate a lot of things. I've had an 18 and a 22 and I love them, still one of the coolest looking boats on the water. I love small boats too but echo exactly what was said, not the best top speed boat. They are great at cruising through chop and are fun within their limits. If it was me, I would go more for a turnkey bullet proof small block, 300-350 HP, boat can go 60 mph no problem. Nice setup for the boat. Just my 2 cents.
01-27-2017, 04:42 PM #805000 RPM
- Jan 2017
- 104
- 17
Sounds like you have some first hand expierence with an 18. I have a limited budget, but I spend what I need to get great performance. I have a buddy that builds race engines for A sedan racing that has offered to help me rebuild my 1991 donor 5.7 Mercruiser, but he's pretty busy and has not really focused on marine engine......
i have been thinking seriously about the new SP383. What's your read on that for an 18?
01-27-2017, 05:03 PM #81
Well if it were me, I would go for one of the Mercruiser certified re-manufactured motors, probably the 357 Mag Bravo 4V - 325HP
Probably cost less in the end, bullet proof. They offer a complete 383 as well. Turn key, warranty etc. I think they start around $7,500? And if you were to sell, it is worth more to most buyers. Anything custom is pretty risky for a buyer not knowing the internals for sure. The SP383 is a sweet motor but for you to set it up will probably cost you more than the mercruiser options.
The recommendation to go with a 2" Imco shorty is good too, way easier than changing dimensions but a stock bravo works too. If you're hull is clean, it'll be a 60+ boat, no problem.
Great boat, looking forward to seeing you get it on the water.
https://www.mercurymarine.com/en/ca/...o-sterndrives/
01-27-2017, 06:12 PM #82Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
357 or 383 Mag option from reman is the way to go. Then a standard X dimension for a Bravo or a touch higher. Now you are done and on the water. In a couple of years, when you have more bank and want more speed you can swap over to an Imco shorty but I suspect you will never do it.
blacktruck liked this post
01-27-2017, 06:45 PM #835000 RPM
- Jan 2017
- 104
- 17
01-27-2017, 08:36 PM #84The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Almost forgot one of the most important rigging items, in a 450 horsepower 18 Donzi... What aftermarket hydraulic steering system you going with?
01-27-2017, 09:54 PM #85Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
01-27-2017, 10:45 PM #865000 RPM
- Jan 2017
- 104
- 17
01-28-2017, 04:25 PM #87The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
O.K. That's a start. You can use the MerCruiser power steering pump with all the aftermarket full hydraulic steering systems. What will the rest of the steering be? You definately should not use the factory cable system, at the speeds that 450 horsepower will give you. Mayfair? Latham? Zeiger? Or?
01-29-2017, 10:50 AM #88Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
When you get your drive poke around for a Bravo unit that has BOTH the side water inlets and the inlets in the nose. Not hard to find and then you will never have a problem with water pressure when you are running in the rough stuff and catching some air. Also desirable for re-sale.
01-29-2017, 11:15 AM #895000 RPM
- Jan 2017
- 104
- 17
I guess beyond the steering parts that are on the transom bracket and the steering pump on the engine, I have not thought about what I need in terms of a steering system. I would be interested in your thoughts on what might be a good average system that would get the job done though
01-29-2017, 11:16 AM #905000 RPM
- Jan 2017
- 104
- 17
Good point. I'll take a look at it, but I don't think there's an inlet in the nose. I am reasonably constrained with cash so I don't know that I would replace it, but is there a substitute that would be as good? Maybe a through hull pick up? Does it close cooling system enable some of what you're referring to?
22 Donzi Classic
By Speed Jr. in forum Hulls larger than 20'Replies: 9Last Post: 07-08-2016, 05:01 PM -
Donzi classic 22
By koukrapock in forum General Boating DiscussionReplies: 12Last Post: 10-29-2012, 05:58 PM
