Results 1 to 4 of 4
    May 2009
    What can I test with a DVA?
    I got a DVA adapter for my DVM based on advice from guys here. Can I test pretty much the whole ignition system with it? Stator, timing plate/trigger, and switch boxes/power packs?
    What about coils?
    What about voltage regulators?
    While I'm redoing carbs/water pump/installing CCM reeds, I figure I might as well hit up the ignition system with a DVA just make sure everything looks good there too, right?
    I've been using my 2.0L power head for a couple of seasons and exactly as I got it from eBay. Never checked anything out. It ran fine for the past two years, but I want to do the CCM reeds, so I might as well do everything, I figured.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    Ft. Lauderdale, Fl
    The DVA is for the stator, timer base and switch box output. The coils are tested with an ohm meter and spark checker. Volt meter, ammeter and ohm meter for the charging, starting and other electrical systems.
  3. Likes pointer liked this post
    Nov 2002
    Lake Lanier - Atlanta, GA
    You can test everything in these charts that apply to your ignition...
    https://issuu.com/cdielectronics/doc...ode=doublePage
    Or, find any ignition issue using their troubleshooting guide;
    http://www.cdielectronics.com/troubleshootingguide/
    May 2009
    Thanks, guys both of you. 'Bum, you are always a reliable help. Thanks, mate.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  1. 21' VEE Test by S+F
    By TUFFboat in forum General Boating Discussion
    Last Post: 05-10-2004, 12:10 PM
  2. test
    By spn#43 in forum Posting Questions and Suggestions
    Last Post: 02-03-2004, 07:03 AM
  3. take the test
    By bulldogdaddy in forum The Scream And Fly Lounge
    Last Post: 11-21-2003, 04:48 AM
  4. Take the test!!! Must be over 18!!
    By skydog in forum The Scream And Fly Lounge
    Last Post: 11-12-2003, 09:59 PM
