Results 46 to 57 of 57
Thread: stratos 180 vt in ga
01-02-2017, 09:56 PM #46
OK, that's 3 votes for the V8 being too heavy for this ride, with me included. I'm currently putting together a 3.0 looper to have ready for the spring. I was gonna put it back on my SK, but I think I'll try it first on the Stratos. I had the V8 on the SK for one river run, it was about 6 mph slower than the bone stock 200 XP 'Rude pushed it.
01-03-2017, 09:26 AM #47
It's all in Weight to Power ratio! You've seen a smallblock whoop-up on a big block many times in drag racing. Bottom line....200hp in a sled that weighs 2000 lbs or 200hp in a sled that weighs 1500 lbs!!!!
Of course there are other factors but on water, 100 pounds is alot when you're borderline to airing out!!
01-03-2017, 01:35 PM #48
Agreed! That's why when I re-did the inside of the boat I tried to keep it light. I know it's a heavy hull, I added drains in the 2 outside sponsons and the glass was almost 3/8" thick. I think I'll bolt 2 of my jackplates together and try a 10" setback with the 200 looper and see what happens in the spring.
WillySteve liked this post
08-14-2022, 07:34 PM #49
180vt rocket
Idk if you still have the boat or not just logged in for the first time in many years.anyone that says they won’t run just don’t know.the 180vt is the same hill as the STV/LTV.but a bit heavier. I built one back in the late 2000s completely restored new stringers transom floor etc. I added one inch to the pad IE “the pad mod” put a 6 inch jack plate and a 3.0L Mariner.added 300 promax intake & electronics,lightened flywheel,cut heads and a coned lower.with no setup time it ran 98mph on gps with a 30 pitch 4 blade Yamaha drag before I burnt a piston and ran out of money.wish I never sold it!
08-14-2022, 09:02 PM #50
When you say you added one inch is that in wider or deeper or both? how far up.
08-15-2022, 09:50 AM #515000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
Jim,,the bottom mode he is talking about was 1st done by T REX on his lasers..I was going to do it,but went in a different direction...The laser LTV has an 11inch wide ,slight V running surface..The mode is a 1 inch squared drop starting from the step to the transom...The theory was according to T REX that it would unload the air faster out of the tunnels......I always wondered if the allison pencil roll would have helped overall performance with that mode...I think for drag racing it would have helped...........My top speed at the rumble on the river was 118.6 on GPS.......
rgsauger liked this post
08-15-2022, 10:48 AM #52
High and dry works
Ed you still racing?We have invented the world; WE see
08-15-2022, 08:21 PM #535000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
08-16-2022, 01:15 PM #54
I hear ya I've been pushing around her wheelchair for 2 years now and she added about 50 lbs.
Going to be driving to Miami Cancer Institute for 20 visits for Proton Therapy for the old prostate
Always something...We have invented the world; WE see
08-16-2022, 08:38 PM #555000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
Good luck
08-19-2022, 11:11 PM #56
Good luck indeed, Cuda
09-03-2022, 10:18 AM #57
I actually sold the boat to a buddy, he was trailering it out to one of our events, when he got sideswiped and ended up rolling his van onto its side at 60 mph. Needless to to say, the boat came off the trailer, and had a ride on the pavement. Now someone bought it from the wrecking yard and is trying to fix it up.
Stratos 285 SKI
By johnyIROC in forum General Boating DiscussionReplies: 1Last Post: 08-21-2017, 12:11 PM -
Stratos 20 vt
By H. Hogan in forum General Boating DiscussionReplies: 39Last Post: 06-10-2009, 09:03 PM -
Stratos set up help
By Lockjaw in forum Props, Setup, and RiggingReplies: 0Last Post: 04-26-2007, 06:43 PM -
stratos VT or MOD V?
By E-rudesoldier in forum General Boating DiscussionReplies: 11Last Post: 05-26-2005, 07:17 PM -
Stratos ?
By GPRACING in forum General Boating DiscussionReplies: 3Last Post: 09-24-2004, 05:32 PM
