Results 1 to 15 of 18
Thread: help
12-02-2016, 09:15 AM #1Junior Member
- Dec 2016
- Toronto Ontario Canada
- 9
help
Hey there guys got a question for you.
So i picked up and stv charger the other day that suposibly has a 200 blackmax on it. i was planning to redo the motor cover and i pealed off the sticker. Under that was a merc xr2 sticker. I know these motors are harder to come by and i wanted to know if it is a 200 or is it the 2.0 150hp. the vin on one side has been scratched off i believe is there any other spot someone might knw where it is the motor is a 1990 any help is much appricated
12-02-2016, 09:26 AM #2
Look for serial number on welch plug on top of motor and post
12-02-2016, 10:14 AM #3Junior Member
- Dec 2016
- 9
12-02-2016, 10:39 AM #4
Looks Like a 1985 V-200
http://store.oldmercs.com/category_s/2687.htm
Mercury Shop Manual # 90-821303
If the cowl has the vented louvers, the guy was just after that for the motor. I believe the XR2 came with that cowl.
JamesLast edited by W2F a V-King; 12-02-2016 at 10:43 AM.
12-02-2016, 11:37 AM #5
150 1985 elpto xr2 a114514 - a904645 Bud Conner "Heathen" "Defending Our Constitution"
12-02-2016, 11:42 AM #6
Motors cowls and mid sections get changed all the time especially on older motors as parts go bad.
need the number off the power had itself and some pics would help
12-02-2016, 11:55 AM #7
1985 0A129684 1200745 MERCURY 2.4 200 EXLPTO if thats the number on the welch plug
12-02-2016, 01:31 PM #8Junior Member
- Dec 2016
- 9
This all I have for pictures atm. I looked all over the block for other numbers didn't see any.a y need to take some more on Sunday
12-02-2016, 01:37 PM #9
Remove the Cowl. Look right between the two heads center of the block TOP. There is a welch Plug (i.e. Small Freeze Plug. There is a Block Serial number stamped on the welch Plug..
12-02-2016, 01:40 PM #10Junior Member
- Dec 2016
- 9
I already have the W plug code that was on the top of the head
12-02-2016, 01:44 PM #11
Its not on the head. Its right in the center of the block between both heads directly on top right above the coils.
What is that serial number? If its the one you posted A129684. I have already posted what you have.Bud Conner "Heathen" "Defending Our Constitution"
12-02-2016, 01:48 PM #12Junior Member
- Dec 2016
- 9
OK I can't check until tomorrow thanks for the info I let you guys know.
12-02-2016, 03:03 PM #13
horizontal or vertical front?
12-03-2016, 11:20 PM #14
So If I were standing in Kansas, would the front be the side facing California or the side facing New York?
12-04-2016, 01:02 AM #15
