Results 1 to 15 of 17
Thread: Venom - 225 Promax
11-20-2016, 11:20 AM #1Junior Member
- Sep 2007
- 27
Venom - 225 Promax
Mornin! Just throwing it out there - any Venom owners see 100mph with a 225 pro max??
I'm running a 15" with stock limiter 6750 and have seen a top speed of 97 with a 32ET. Should I be happy? 4 seater fully furnished Venom.
Some jackass suggested I try a 32 cleaver. Thoughts?
11-20-2016, 05:04 PM #2
What rpm you turning?
11-20-2016, 06:42 PM #3Junior Member
- Sep 2007
- 27
11-20-2016, 07:27 PM #4
Not sure if I'm the jackass or not but my Venom handles
perfect with a 30 cleaver on a 15" 200 EFI.
A lot of people were at this past Suwannee run and cantell you my boat has no straight line or cornering issues at all
spinning a cleaver to 7000 rpms with 1.87 gears with a CLE case.
Great boats when set up correctly. I don't like the ET cut on the Venom
for top end runs. Boat hull makes plenty of lift.
RNM018 liked this post
11-20-2016, 07:35 PM #51980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
11-20-2016, 10:23 PM #6
Definitely go cleaver. ...I agree with Dave on the 34p . I don't have the venom but when I switched to a cleaver, my top end increased and chine walk decreased significantly.
11-21-2016, 06:18 AM #7
dagodiver's boat hauls the mail,,saw it at the Suwanne Run
11-21-2016, 07:02 AM #8
A jackass would have told you to put on a chopper... just my $.02
11-21-2016, 08:22 AM #9
Pull the limiter and call it a day....You don't wanna go any taller than a 32 anyhow.....My 2 cents.
Larry Gempp Jr.
11-22-2016, 03:30 PM #10
a pro max doesn't really have a "limiter" per say in the normal sense, they just start going fat so it won't turn up any more.
Going a little over the limiter is normal, with a short wheel I've hit 7500 on a stock ecu because rpm's climbed so fast then it comes back down some but not all the way
But if it were me I'd send ecu off and have it tuned to turn 74-600 so you don't have to try and run a huge wheel and fight it
W2F a V-King thanked for this post
11-22-2016, 07:44 PM #115000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
If you haven't put it away for the winter yet I've got a cleaver you can try.
11-22-2016, 08:05 PM #12Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
Is there more speed to be had with some gear case work?
02-03-2017, 09:08 PM #135000 RPM
- Jan 2005
- levitown
- 696
My venom does 90 with a 2.4 4 blade re4 30p
And with a 260 it break 100 any prop any pitch any amount if people .
02-07-2017, 01:11 PM #145000 RPM
- Mar 2002
- SW FLA
- 162
11-07-2017, 10:31 AM #15Junior Member
- Sep 2007
- 27
Just an update to this thread - I moved the limiter (Thanks Simon) to 7400 and tossed on a 30 cleaver (4 blade) and did 103. I know a 3 blade will be quicker... but we have to wait until next summer to find out!
WTB 300X or Promax cowl, side ram for offshore Promax mid, Sportmaster internals
By bayratpg in forum Parts WantedReplies: 0Last Post: 04-06-2016, 09:49 PM -
what prop should i use? 225 promax hydrostream venom
By shenson101 in forum Props, Setup, and RiggingReplies: 10Last Post: 03-23-2012, 10:22 PM -
whats the difference in 98 venom 225 and 98 venom 250
By area51 in forum Technical DiscussionReplies: 1Last Post: 03-06-2006, 10:24 PM
