Results 1 to 8 of 8
    Jul 2008
    St. Cloud MN
    cowl scratches . . . advice
    Hi all. . . . merc 280, cowl has some scratches. . . deep enough that you can feel with your fingernail. . .ow aggressive can I get? Can i wet sand? how 'thick' is the black, or is it through and through? any other advice, thanks ahead of time!
    Jul 2008
    St. Cloud MN
    Found the answer, thanks everyone!!
    Feb 2008
    Hudson, WI
    Let us know what the answer is
    Jul 2008
    St. Cloud MN
    it's a long process. . .haha. . . i had to go as low as 400 on some, then stepped all the way up to 3000, block for it all to prevent and waves, and then a 3 step buff. . . . . 4 1/2 hours later, looks new again. . . brought me back to my body shop wet sanding days. . .haha
    Baton Rouge, La
    More details on the buffing products and pad types please ! I did my drag hood years ago with my painting buddy. Well , I taped decals and sanded. He buffed. Looked new again. Hit the bad scratches with 320. Thanks Mike
    Cheaters never Win !!!
    Jul 2008
    St. Cloud MN
    I used a combination. Yes, some areas all down to 320, but be very careful and use a block so as not to get any flat spots in the cowl. Then up to 400, 600, 800 dry, 800 wet, 1000 dry, 1000 wet, 1200 wet, 1500 wet, and 2000 wet. Then I used a cutting compound with a yarn pad, then a medium polish compound with same pad (i used McGuire's products this time, sometimes use 3M), and then a foam pad of cleaner wax, foam of then straight carnuba. She got hand waxed then with collinate marine wax. As you can tell, lot of steps, only scratches did i go as aggressive as needed, whole thing done 1200 wet and above though. Hope that helps :-)
  7. Thanks David - WI thanked for this post
    Baton Rouge, La
    Thanks. It worth the time to make it look new again. Mike
  9. #8
    Apr 2017
    going to have to try this out for sure! thanks for the info!
  10. Likes Zukiride liked this post
  1. How to get rid of surface scratches
    By daniel475 in forum Detailing and Care
    Last Post: 06-09-2015, 12:47 PM
  2. Prop scratches
    By Robertrosen in forum Props, Setup, and Rigging
    Last Post: 12-12-2010, 08:57 PM
  3. remove scratches
    By riverboater in forum Fiberglass and Composites Discussion
    Last Post: 02-09-2006, 06:46 PM
  4. Getting ready to paint cowl, need advice.
    By imq707s in forum General Boating Discussion
    Last Post: 04-21-2004, 11:01 PM
  5. Getting minor scratches out.
    By bobecke in forum Fiberglass and Composites Discussion
    Last Post: 12-12-2003, 12:29 PM
