Results 1 to 8 of 8
    Aug 2015
    Silver Spring, MD
    WTB Mercury Inline 6 Dual Ride Guide steering tube
    Hey guys - I am looking for a Mercury Ride Guide Dual Steering tube which I believe is part #55509A1. I need this for a HydroStream Viper with inline 6 project I'm pulling together. Any leads are greatly appreciated. Thanks, Darrel 202-468-61zero5
Name:	Hydro Viper 21b.jpg
ID:	360609 Click image for larger version.
Name:	Hydro Viper 21a.jpg
ID:	360610Click image for larger version.
Name:	78 Merc XS (12).JPG
    SW Florida
    I need one of these 55509A1 for my latest project, Allison 14 copy with 115 tower of power. Anyone have one or know where to get?
    .Click image for larger version.
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
    Not too hard to make out of some flat stock and a steering tube from an alpha transom assembly. That looks like fun btw
    Jun 2001
    I have one that was a bit rusted, been sandblasted and black powder coated. You might talk me out of it for the right price... PM me an offer
    SW Florida
    Quote Originally Posted by Tom Smyth View Post
    I think I have a deal pending on one with someone thank you I'll let you know if it doesn't go through
    Jan 2008
    Amesbury, ma
    I made this one if you pinch in you can see it. It was easier than finding a Merc one and allows tensioning cables against each other to remove play. 7/8-14 thread for steering cable if remembering right.
    I got everything I needed from McMaster Carr tubes,nuts and taps, except the two brackets, I had those made from flat stock. I also made the end piece connecting the two cables where steering arm attaches but a stock Merc one would have been fine, those are easy to find. You make brackets with two holes same distance apart as the end piece cable centerlines. I ran my cables from same side but would work either way.
    Attached Thumbnails Attached Thumbnails 565478B7-E8E9-4315-B30D-0BE794865910.jpg
    Current rides
    74 Vector, 74 Merc 1500
    75 Glastron GT 160 76 Merc 1150
    65 MFG 66 Merc 950
    58 Hiliner, 62 Merc 700
    82 Century Resorter (restoration in progress)
    83 Century Arabian 454 LS6
    78 Chris Craft Lancer 23
    2000 Keaton 18 J jet, last one ever built by Jack.
    SW Florida
    I installed mine last night. I don't understand how it's supposed to tilt unless you leave the motor bracket tilt tube nuts a little loose. I feel like it needs a bearing or at least a vinyl washer on each side of the add on second steering tube bracket so that the second steering tube can move with the tilt.
    Those who have had this setup. What did you do about that just leave the nuts a little loose?
    I don't feel like that's the right solution. Here is a video of min with the nuts tight. You can see it starts to bind.
    Photos/Video:
    https://photos.app.goo.gl/mvFsfSotGzE33h2dA
    SW Florida
    The guy I bought my secondary steering tube bracket tells me to just snug the primary steering tube nuts. Still seems like it puts a lot of stress on the arm that goes from the end of the two cables to the tiller. I'm thinking new lock nuts so the vinyl is good and some thin plastic bushings in between for the bracket to ride on.
