Results 1 to 5 of 5
    How to launch/tilt 20HP mercury??
    14' Aluminum w/20HP Merc. First small, non hydraulic tilt for me. So you get to the lake, take of the motor saver, let motor down to lock pin. How do you tilt and hold motor while backing in and how do you place it in run position when I'm in boat? I'm going to feel dumb, but educated, when I hear the answers. Thank you.
    Jun 2009
    central minnesota
    must put in foward.hold up with tilt lock lever.-th
    I need it spelled out better. I am not savvy on it. Shift into forward, then hold motor up with tilt lock lever. Will this lever hold motor up high for launch? Then how to put motor back down? Shift back to neutral, let it down and start motor? So the shift lever operates the lock hooks? WOW!
    Jun 2009
    central minnesota
    let it down,then shift into neutral, or motor will bend hooks closed.many 40s/50s/60s are in this condition-th
    Thank you.
  1. Mercury Tech: 95' 20hp mercury
    By Hmrtym84 in forum Technical Discussion
    Last Post: 04-19-2016, 08:07 PM
  2. Event Photos: ** Miami Boat Show 2015 - Mercury Launch of Verado 400R, 350, 1550, Nor-Tech 390CC **
    Last Post: 02-19-2015, 07:24 AM
  3. Article: Mercury To Launch Ship’s Log Mobile App
    By Scream And Fly in forum vBCms Comments
    Last Post: 09-27-2012, 09:59 PM
  4. Help on 1978 20hp mercury
    By Midnight Runner in forum Technical Discussion
    Last Post: 11-10-2005, 11:42 PM
