Results 1 to 5 of 5
    Courtice, Ontario, Canada
    Aftermarket trim: Panther power trim and tilt bracket opinions?
    Looking for an aftermarket power trim and tilt for my sons Hydrostream Voodoo with an older Evinrude 50hp. I came across a Panther model 55 power trim and tilt bracket for a good price. Anyone use one of these? Opinions? Good, bad?
    Thanks
    1996 Allison GSE /200XS
    1977 Hydrostream Ventura / 150 Mariner MAG III
    Jun 2004
    Pelican Lake, WI
    I have one on a gw invader mod 85 Suzuki set up high enough to have prop shaft even with pad. Seems plenty strong wish it trimmed a bit faster. I did have the relay crap out this summer for the trim but not sure how old it is didn't buy new. I have had the boat into low 70's with no issues. Hope this helps
    Thanks for the info 97 Twister.
    Jun 2009
    central minnesota
    never put that much power on one,lots of them around here on all kinds of rigs including pontoons,relays same as on newer units,but most relays podded and that requires upgrading wiring harnass.lot of older units need replacement power units.Panther now HQed in White Bear Lake MN..more info?call me daytime for compleat info terry 6123902474
    Jun 2004
    Pelican Lake, WI
    Quote Originally Posted by mn808gade View Post
    Isn't this model rated for up to 250lb motor? I should have asked but I assumed he was talking about a 2cyl motor which should be fine. I realize my application is pushing the limits and don't really suggest doing many things I do lol. As always be safe, wear a good life jacket and check you rig before and after every use.
  1. Need some opinions on a trim/tilt unit
    By Bartman39 in forum Technical Discussion
    Last Post: 11-30-2008, 05:51 PM
