Results 46 to 59 of 59
Thread: johnson stinger gp
02-26-2019, 03:16 AM #46Junior Member
- Mar 2018
- Kaiapoi, New Zealand
Are there any pictures of the trim cylinder for the super strangler, is it true it is similar to a prestolite tilt cylinder for a Chrysler outboard
02-27-2019, 01:57 PM #476000 RPM
- Jun 2009
- Georgia
- 1,006
- 232
- 9
- 365
- 39 Post(s)
If my memory is correct both the cylinder and pump assembly are stock Merc parts. The lift pump assm. was the same unit as the trim unit, it just didn't use the Merc cylinder. The lift cylinder was incorporated into the swivel tube.
02-27-2019, 03:27 PM #486000 RPM
- Jun 2009
- Georgia
- 1,006
- 232
- 9
- 365
- 39 Post(s)
This is a link to e-bay for the pump assm used for thrim and lift. I believe it was made by Prestolite.
https://www.ebay.com/itm/Mercury-Mercruiser-used-vintage-power-trim-pump/143126049237?hash=item2152fa31d5:g:nqUAAOSwUvVcYG3P:rk:81f:0&vxp=mtr
02-27-2019, 03:44 PM #49Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I've seen pics of the earlier 62,63,64,65+ years using the exact tilt and pump as on the late 60s early 70 Chrysler before the trim cylinder was added. If you could build a pad for the trim ram to contact maybe it could be fit between the clamps. The tilt and valves likely wouldn't hold trim position. The trim and tilt as CHRYSLER also has a shock upright port side clamp , the trim between the shock and tilt tube. The later Force pump is a better choice , the trim and tilt and shock , same as earlier. Same mounting for the pump. The last style Force pump for the Merc years, not sure about the mounting but maybe worth checking everything for fit. The earlier Force pump is a bit taller than the CHRYSLER.
02-27-2019, 03:49 PM #506000 RPM
- Jun 2009
- Georgia
- 1,006
- 232
- 9
- 365
- 39 Post(s)
I believe this was the cylinder made by Prestolite
https://www.ebay.com/itm/Force-Prestolite-Outboard-85-90-120-125-HP-Power-Tilt-Trim-Cylinder/153352616082?hash=item23b4873892:g:W7AAAOSwXItcL~Uj:rk:16f:0
02-27-2019, 03:51 PM #51Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Yes that's it, tilt only. Use 30sae non detergent, the trim and tilt work well.
02-27-2019, 05:20 PM #526000 RPM
- Jun 2009
- Georgia
- 1,006
- 232
- 9
- 365
- 39 Post(s)
Trim only, no tilt. OMC used 2 of the pump assm, one for the trim and 1 for the lift.
02-27-2019, 06:23 PM #53Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That's a tilt cylinder though, no and if or buts.
02-27-2019, 06:33 PM #54Junior Member
- Mar 2018
Is there a picture of the trim ram that attaches to the housing inside the well
02-27-2019, 07:11 PM #55Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
The last style was pump and single ram between clamps. Maybe it could fit?
https://m.youtube.com/watch?v=bOfTyiAjfuM
02-27-2019, 08:39 PM #567000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Ken Cook company has a reprint of the original StingerGP parts and owner manual. Helps a lot to figure out what parts you have, are missing, and go together.
https://www.outboardbooks.com/manual/KR15M/Johnson
02-27-2019, 08:44 PM #57Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
02-27-2019, 09:10 PM #58
03-04-2019, 02:23 AM #59Junior Member
- Mar 2018
Can someone tell me why I could use a force tilt ram for trimming?
my old johnson stinger gp
By Kellyt21 in forum Outboard and Racing HistoryReplies: 6Last Post: 12-03-2016, 11:22 AM -
OMC Tech: 75 johnson stinger (need help)
By hoppinhydro in forum Technical DiscussionReplies: 3Last Post: 08-23-2012, 06:04 PM -
55hp johnson 3 cyl and 75 hp johnson stinger
By john rowley in forum Technical DiscussionReplies: 1Last Post: 05-02-2011, 02:32 PM -
johnson stinger
By concord 1 in forum General Boating DiscussionReplies: 10Last Post: 05-31-2010, 12:42 AM -
1978 Johnson Stinger vs. mid 1980 Johnson's
By fairbanks 1977 in forum Outboard and Racing HistoryReplies: 2Last Post: 08-04-2006, 06:40 PM
