Results 1 to 2 of 2
Thread: 115 HO Etec Cowling
09-26-2016, 07:29 PM #1Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
115 HO Etec Cowling
I have had the cover off before, but either am having brain fade or a problem. Front levers, turn down and rotate. Same thing with rear lever. Cover doesn't budge. What am I missing?
09-27-2016, 06:24 AM #25000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
Pull latch out off the retaining stud, rotate down - sounds like your doing it right.
Sometimes they are a tight fit. The air vent at the rear top of the cowl is a good spot to give it a little nudge, helps get the cowling off the side panels.
pointer
Etec cowling be modified to fit on older 3.0L omc
By RayburnRacer in forum Technical DiscussionReplies: 11Last Post: 01-30-2009, 03:49 PM
