Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    lindsay on. canada
    you have better eyes than I then , look out of prop there should be water flow out around the muffs and the prop ....nothing that I see ....but I could be just blind ..
  2. #17
    Quote Originally Posted by frank jackson View Post
    Black and white tv ?
  3. #18
    there is water coming out the tell tale for sure.
    and ive used power tune with very good results.
    I thought imust of had mug written on my head when I got home with and read the instructions.
    anyway went ahead and done what it says, except I left it in a good deal longer.
    Now I thought my engine was running sweet to be honest, but after the power tune it was miles better, idled better and even
    the sound of the engine was crisper.
    you have just reminded me to get another tin of it ha ha .
  4. #19
    Dec 2012
    Moses Lake, Wa.
    Taking into what's already been said, The directions say to warm up the engine 1st and then spray into the intake freely, till it smokes like the neighborhood is on fire!! Do it over on the gravel on the side of the driveway.as it will make a big mess. .....Tho I've used it many times, it can't but help but by cleaning up the "coking" around the top and upper sides of the pistons and around the rings. Supposed to do the deed every year but I doubt if many do. And, a lot of mechanics will douse the engine the night before (and not blow it clear) they have to tear it down. Personally, I think it's much better the use a fuel system cleaner/conditioner such as Merc's #1 and #2 and fairly high quality oil while making sure the engine thermostats are bringing the block temp up to temp.
  5. #20
    Aug 2009
    savannah,ga
    My experience made the locator pin on one of my pistons fall out on my 85 2 liter XR2. Will never use it on a 2 stroke again after that....and my dumba** is an outboard tech as well. The stuff works great on four strokes but don't use it on any older 2 stroke motors when the carbon is holding the locator pins in their proper place.
  6. #21
    Quote Originally Posted by johnboy 88 vegas View Post
    If carbon is holding your ring pins in place motor should have been rebuilt long ago.
  7. Likes Slimm liked this post
  8. #22
    Aug 2009
    savannah,ga
    Quote Originally Posted by Dave Strong View Post
    This was a $800 junk motor that only needed a powerpack and carb job to run....this was a don't give a **** motor for testing different mods. Sprayed it with Powertune after I river tested the first time. The second time I run the motor on my 15 Champion it turned 6800 all day long. Got back to the house and started flushing it out....popped the pedal one time to 3k and the pos spit a piston ring out the prop. Sorry for the sarcasm.
  9. Likes Dave Strong liked this post
  10. #23
    Ft. Lauderdale, Fl
    It would have fallen out eventually regardless
  11. Likes phillnjack liked this post
  12. #24
    Lol, so power Tune was not the problem. Just had a ticking time bomb.
  13. Thanks phillnjack thanked for this post
  14. #25
    Thats like saying put fresh air in the tyres now ive got a puncture.. that pin would not be held in by a little bit of carbon...
  15. #26
    Sep 2019
    madison wisconsin
    I knew a guy that worked in fondulac at merc asked him.about this he said yes can do it this way but its extremely hard on seals doing it overnight. Letting it sit for an.hour is the safest
  16. #27
    Sep 2017
    Ashland city tn
    Quote Originally Posted by phillnjack View Post
    I e actually heard and thought myself , with a carboned up motor , if u clean it well and it's got lots hrs , and starts turning higher , I've heard it comin apart b4 , maybe just coincidence maybe not , I just try keep em kinda clean frm day 1 and not let em get built up. just a opinion
  17. Likes phillnjack liked this post
  18. #28
    Houston, TX
    As was said, you can do the same thing with seafoam and it absolutely works. Spray in the carbs and spark plug holes.
  19. #29
    Nothing beats power tune, best stuff ever, especially for cleaning green fourstroke carbs.
  20. Thanks phillnjack thanked for this post
    Likes Dave Strong, phillnjack liked this post
  1. Power Tune - educate me
    By Stoker1 in forum Technical Discussion
    Last Post: 01-13-2014, 02:56 AM
  2. how to decarb my 300 promax with power tune?
    By dschifan in forum Technical Discussion
    Last Post: 02-22-2010, 01:02 PM
  3. Power Tune
    By JW in forum Technical Discussion
    Last Post: 08-07-2002, 07:51 PM
  4. Does anyone use Power Tune in their engines
    By skatermike24 in forum General Boating Discussion
    Last Post: 03-06-2002, 06:55 PM
  5. Mercury Power Tune
    Last Post: 08-01-2001, 06:34 PM
