Results 1 to 9 of 9
09-09-2016, 03:47 PM #1Member
- Aug 2016
- Minnesota
- 84
Differences between 1995 2.5l black max xri 150 and 175
Dumb question I guess but I have read a few places that try to identify the differences between the two motors and I am just curious if there are basic things I could bolt on that would make it similar to a 175...
1. Reeds
2. Fuel mapping
3. Remove extra long tuner
People have talked about porting being different is that just the tuner?
Sorry if these are dumb questions its just a fishing boat and I have been thinking about tinkering and learning a little.1995 ProCraft SuperPro 180 / Mercury 150 XRI
1997 ProCraft SuperPro 200 / Mercury 225 3L
09-10-2016, 07:04 AM #2
Reeds will be the same. Fuel map likely a bit different. Definitely a shorter tuner on the 175. Most likely the ports have slightly different locations and/or sizes and shapes. Then again some motors are nothing but compression and timing. Ports are located in the cylinder walls and have nothing to do with the tuner. No questions are dumb when you are trying to learn something. Good luck.
RockTeam Junk
09-10-2016, 09:01 PM #35000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
What kind of performance gain are you needing..? Little more top mph, or more pep mid range, hole shot take off..
09-12-2016, 09:11 AM #4Member
- Aug 2016
- Minnesota
- 84
More curious then anything...
I have ProCraft Super Pro 180 and it currently has a 25p Lazer II prop... People have been saying in the bbc setups that im setup wrong but I am not sure they realize there is a difference in the super pro and the regular bass versions.
I don't really feel it needs anything major but have seen some info on the exact boat with a 175 pushing a 25p Tempest and having really good results and was curious how hard it would be to modify my motor to reach a similar hp since I have access to that prop. I read a bunch about the motor being mostly a neutered 175 and thought there might be a quick fix that wouldn't be to risky to the motor... if not it performs pretty good as is
Appreciate the information!1995 ProCraft SuperPro 180 / Mercury 150 XRI
09-12-2016, 09:21 AM #5Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
If you are running it hard and since it is an older motor, I would suggest a set of fiber reeds for peace of mind. The metal stock ones will take out your motor if they fail. They don't last forever....Might be a little better runner too. Chris Carson Marine has them. Good guy to deal with..
09-12-2016, 09:24 AM #6Member
- Aug 2016
- Minnesota
- 84
I had the whole motor gone through recently... had a metal oil pump gear put in, cleaned the fuel injectors, voltage regulators, put in bobs motor mounts.
Not sure if they would have looked at the reeds or not? what would the reeds do for performance? Would it risk hurting the motor at all?
As for running it hard its just a bass boat but its pretty fun to open up
Thanks!1995 ProCraft SuperPro 180 / Mercury 150 XRI
09-12-2016, 09:45 AM #7Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
All I can say is, it's not IF they are gonna fail. It's when. How many hrs on the motor? I run chris's fiber reeds in a couple of my motors. Run smoother and may have a little more pop. Easy to install and not real expensive either.
09-12-2016, 10:38 AM #8Member
- Aug 2016
- Minnesota
- 84
Motor is in good shape now wasn't used much.
I will look into the reeds.1995 ProCraft SuperPro 180 / Mercury 150 XRI
09-14-2016, 05:41 PM #95000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
I put a set of chris carson reeds in a 150 merc.. it idled cleaner and gained 100 rpm maxed out..all good things very happy with that purchase
1981 Allison Craft GT20 with 200 Black Max and optional 200 Black Max for sale
By noj in forum Hulls up to 20'Replies: 29Last Post: 06-21-2016, 10:21 PM -
1995 Mercury 200 XRi - Please Check for correct Oil and Black Box Delete - PICS
By mram10us in forum Technical DiscussionReplies: 7Last Post: 03-04-2015, 11:52 PM -
Mercury Tech: 1995 Black max 200 xri efi - school me!
By keit29 in forum Technical DiscussionReplies: 10Last Post: 10-09-2013, 09:10 PM -
Small black box below ECU on 1995 EFI red light
By xb03fs in forum Technical DiscussionReplies: 2Last Post: 07-18-2010, 10:28 AM -
1995 225 Black Max...how much power can i make??
By 302Sport in forum General Boating DiscussionReplies: 11Last Post: 09-06-2008, 12:07 PM
