Results 1 to 3 of 3
Thread: Faded shift release mechanism
09-07-2016, 09:15 PM #15000 RPM
- Mar 2002
- SW FLA
- 162
Can u buy the red part that u squeeze to shift gears on a mercury flush mount shifter it's on an Allison the handle is faded pinkish I see a lot like this like the shifter Don't want to replace it?
09-08-2016, 08:49 AM #2
You can get trim switches but never tried to replace that part. Good Merc parts guy should be able you tell you.
09-08-2016, 04:13 PM #35000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
I've had the control boxes apart for key switches and trim buttons, never to replace the safety lock, but don't see why it couldn't be done.
The local BRP dealer takes Merc contols out a few times a year to replace with OMC, I'm sure there must be a non Merc dealer in your area who does the same, first place I'd check for one.
Then the tricky part begins!
pointer
Evinrude 115HO propshaft/shift mechanism problem.
By PDaddy in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 01-10-2015, 06:10 PM -
Wanted trim indicator mechanism
By capnzee in forum Parts WantedReplies: 1Last Post: 02-19-2014, 05:15 PM -
Problems with tilt mechanism on 40 Tohatsu
By riverrat321 in forum Technical DiscussionReplies: 0Last Post: 04-10-2005, 12:45 AM -
Faded bow.
By 88 V-King in forum Appearance ModsReplies: 7Last Post: 01-27-2005, 03:59 PM
