Results 1 to 10 of 10
Thread: Why?
    Mar 2014
    Antioch, Ca
    Why?
    My question is, I hope, relatively simple. Why is a BB Chevy using a 4.25"-4.5" stroke is able or capable of spinning 6000 RPM and above, where as a BB Olds doesn't like or want spin above 5500 RPM?
    Jun 2014
    Southern Indiana
    Block design, head and intake design.
    Aug 2006
    virginia
    weak crank shaft design that went into those rod bearing spinning Olds motors
  4. Likes 1BadAction, Mugs914 liked this post
    Sep 2016
    SF Bay Area
    Built Olds can split the block. Can spin bearings. Can crack the crank. But, they can also fly at slightly lower revs. There are plenty of Olds that run
    Aug 2002
    waterloo IN
    Weak block, nodular iron crank, and large bearing journals which leads to super high bearing speeds. Not to menshion limited selection of poor flowing heads. That being said you can make well over 800 NA hp.
    Yes i am an Olds nut.
    limited selection on everything
    Sep 2016
    SF Bay Area
    Except used jet boats with them in there
    BBC is like 383 Mopar and 283/327 Cheby, they will spin and then some. They love to buzz. They are happy puppy motors that are always waiting to rev. Others not so much ...
  9. #8
    Oct 2007
    Los Angeles
    Now....the '65 to '67 425 Olds likes to rev. Same bore as 455 but shorter stroke, steel crank, studded rockers....good platform to start with when looking to build a Big Olds. Much more selection of heads and speed parts available now. I believe a company called something like "rocket performance" manufactures a super strong aftermarket block now as well. It's all out there for the legit hard core wrenchers.
  10. #9
    The 425 also had larger lifter bores and a different bank angle. The longer stroke 455 will turn rpm. All these motors in hipo use could use a main girdle with oil passages modded to use the oil down low.
    The small block diesel 350 is tough block. Can be bored 4.125 and accepts the big block cranks for big cubes in a small package. The earlier small block 330 has a forged crank, can be stroked as well. The small block 403 has the largest bores from all , big or small block . A couple thousand were trailer package wagon big car motors that didn't have the windowed main web. With proper build this and the 330 crank puts out a good punch.
    I heard of these blocks modded to accept the big mains of the big block crank like the 425 crank.
    Yes I've heard of a new aftermarket block.
    Joe Modello, Dick Miller, Rocket Racing, BTR .
    Zooooooom!
  11. #10
    Dec 2001
    FMP.... good info.... had a 330 was a funnn ride..... 1967 cs/conv/4 spd....pdb.....$250... HeeHee...
