Results 1 to 1 of 1
Thread: Early early 200 merc
08-30-2016, 07:25 PM #1
Shortblock is together bores look good as heads has two piston ram that I never saw complete w ING. Carbs starter with 9 tooth gear and flywheel needs rebuild rods look good. But won't spin either top or bottom bearing is stuck or crank ring is. Was running 9 years ago comes w reload gearcase that propshaft spins but drive shaft does and clamshells and 14 pin harness and controls 500 boo no shipping pick up only remember this has the early head bolt setup might have big rods
Mercury Tech: early 2.0 merc mods?
By `80 V-King in forum Technical DiscussionReplies: 4Last Post: 05-05-2012, 11:27 AM -
Mercury Tech: Early 80's 225 Merc ????
By 97 TWISTER in forum Technical DiscussionReplies: 7Last Post: 07-17-2009, 05:34 AM
