Results 1 to 6 of 6
Thread: Mercury 150 xr2 blown
08-22-2016, 07:50 AM #15000 RPM
- Apr 2007
- Wilkesboro, NC
- 113
- 15
S/N is 06568658
Complete motor minus stator and rectifier. Water pump and gear lube changed this summer with less than 5 hours run time since. It has the lager lower unit that will work on any 2.0,2.4, or 2.5. Gear ratio is 2:1. Carbs (WH-29) and fuel pump were just rebuilt using new mercury rebuild kits along with all new fuel and bleed lines under the cowl. Locator pin backed out on number 6 and ring caught a port. There is no holes in the block and motor was still running when taking off the boat. But will need a rebuild. Motor also has the heavy duty clamp and single ram trim. Will come with remote trim pump as well.
Motor only. No prop or controls.
Price is $650 picked up. The lower unit is worth almost that.
Thanks
Matt
08-23-2016, 02:14 PM #25000 RPM
- Aug 2008
- Stoneville NC
- 677
You should have a PM from me.. Or call me at 336-362-2624 Bob
20ft Gambler with Merc 260
Too many projects to liist..
08-24-2016, 10:59 AM #35000 RPM
- Aug 2008
- Stoneville NC
- 677
Matt give me another call.. I can use the cowlings if they look that good on both sides and consider it sold pending funds.. But call me back.
08-24-2016, 11:30 AM #45000 RPM
- Apr 2007
- Wilkesboro, NC
- 113
- 15
Sale pending. Thanks
08-26-2016, 05:15 PM #55000 RPM
- Aug 2008
- Stoneville NC
- 677
Matt, I need your address. I saved your number.. I sent you a PM with my email if you want to send me your address.. or TX my phone with it.
08-26-2016, 07:29 PM #65000 RPM
- Apr 2007
- Wilkesboro, NC
- 113
- 15
Pm sent with address
Thanks
blown 1996 2.5 175 mercury efi
By bahamatrama in forum Outboard EnginesReplies: 2Last Post: 07-12-2015, 05:42 PM -
Used Mercury XR6 150 w/blown powerhead
By Speed & Custom Marine in forum Outboard EnginesReplies: 1Last Post: 05-21-2014, 01:01 PM
