Results 1 to 15 of 19
Thread: water pump question
08-01-2016, 07:22 PM #1
08-01-2016, 07:41 PM #2
that's guide tube,can get it alone...
TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
tux974 liked this post
08-01-2016, 07:57 PM #3
the guide tube is the little plastic bushing that slides under this? is this the dip tube in picture?
08-02-2016, 10:45 AM #45000 RPM
- Apr 2002
- wisconsin
- 843
- 20
Are u thinking of the black rubber "bushing" that sits inside the water pump housing that the water tube goes into. {It sits below the guide tube} These can be bought separately.
garybvd
08-02-2016, 03:33 PM #5
yes I believe its the bushing, what can I search for to find just that part?
08-02-2016, 03:55 PM #6
26-38970 or 18-3110 sierra . Fit 1/2 inch water tube,dont try to run it with out the grommet.
08-02-2016, 05:57 PM #7
thank you
08-04-2016, 05:02 PM #8
I got the part today, I dont think its the right one, is there a plastic (black bushing) that slides under the dip tube where my finger is pointing? this is the part I got, it dosent go over 1/2 in copper tube, im pretty sure the part I lost slid down the copper pipe into white dip tube, but I could be wrong?
08-04-2016, 05:03 PM #9
08-04-2016, 05:26 PM #10
If you are speaking of the black piece at the adapter end of the tube there is one at each end. Remove the plastic guide tube and insert into water pump housing. Make sure there is not one already there as they usually don't just fall out. Tube should not go thru "bushing". It is tapered and will fit snuggly on tube. Apply a little lube before assembly.
RockTeam Junk
08-04-2016, 05:31 PM #11
I do have the rubber adapter piece under the guide tube at pump housing, but does one also go at the end of copper when it gets raised back into mid section? I stuck it on the end for viewing purposes, I just could have swore I lost a small black bushing or something when I lowered it, but havent found anything
08-04-2016, 06:21 PM #125000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Was it the soft rubber ring on the driveshaft? Maybe it split and flew away.
08-04-2016, 07:53 PM #13
not sure, searched my garage bunch of times and cant find anything, trying to just go off schematics to make sure I have all pieces before I put it back on , hard to tell from schematics, but I dont think anything goes under guide tube?
08-05-2016, 10:33 AM #145000 RPM
- Apr 2002
- wisconsin
- 843
- 20
The same black bushing goes on both ends. One helps seal at power head and the other seals at the water pump end. yes there is one below the guide tube. Same part. Ask rock, hes the man.
garybvd
08-05-2016, 02:07 PM #15
ok so it stays on the tip of the copper like in the picture then slides up into mid section?
Outboard jet pump & water pump seal question
By jetriverfish in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 09-02-2012, 06:50 PM -
water pump question??
By gorillapowered in forum Technical DiscussionReplies: 2Last Post: 10-03-2011, 09:49 PM -
300 X water pump question
By boater777777 in forum Technical DiscussionReplies: 5Last Post: 05-23-2010, 07:33 PM -
water pump question
By THE HOGG in forum Technical DiscussionReplies: 2Last Post: 04-13-2009, 11:32 AM -
water pump question
By lild in forum Technical DiscussionReplies: 0Last Post: 06-14-2008, 10:52 PM
