Results 1 to 14 of 14
Thread: V8 alarm full story help!!!
07-11-2016, 09:09 PM #1Member
- Jan 2005
- Montreal Quebec
- 44
Last week the drive shaft from the lower unit broke....I found an use one for good price .This unit have a nose cone on it. After have putt everything in place i have an alarm (constant bip) when come to plane and the engine have no rev like protect mode ...when return to idle the alarm goes off !! Back home remove the thermostat and return to water same think.
help please !!!!
07-12-2016, 07:27 AM #2Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Sounds like it is going into slow due to overheat. I would start by installing a new OEM water pump kit. You mention low water pick up, what size hose and fittings does it have?
07-12-2016, 06:23 PM #3
Could it be the neutral switch from improper linkage setup?
07-12-2016, 07:00 PM #4Member
- Jan 2005
- Montreal Quebec
- 44
I install new oem water pump kit today !! Try this tomorrow morning. i found it is hard to put in gear with propeller at the dock but easy without prop in driveway .
is that switch that kill cylinder when put in gear ??Last edited by boby; 07-12-2016 at 07:13 PM.
07-12-2016, 07:49 PM #5Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Yes that is the switch Tim is talking about but it will not set off your alarm. Switch is more for getting out of gear. When you installed the kit did you make sure all the o-rings were in and sealed? What part number did you use? Your alarm may be from fuel vaccum but that would not put the engine into slow.
07-12-2016, 10:35 PM #6Member
- Jan 2005
- Montreal Quebec
- 44
0395062 water pump repair kit from the dealer i give my model number j300plcem....for the switch i don't have problem to put in neutral !
07-13-2016, 09:15 AM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
That is the original number but if that is what you were sold it is old stock as that number has been replaced at least 2 times to my memory, 434421 and currently by 5001594. The 5001595 will develop a bit more pressure as it does not have the bleed hole in the housing by the starboard rear bolt, this pump is for what are referred to as split line lower units but works good when a couple pounds of extra pressure are needed on non split line. Of note this is not factory.
07-13-2016, 10:00 AM #85000 RPM
- Jan 2004
- lindsay on. canada
- 370
- 14
- 13
- 68
- 34
Is that pump a good pump for a 6 also ?
07-13-2016, 10:40 AM #9
07-13-2016, 10:43 AM #10
07-13-2016, 10:46 AM #11
07-13-2016, 01:23 PM #12Member
- Jan 2005
- Montreal Quebec
- 44
More pressure on my psi gauge but still the same alarm and I put new thermostats . I am on the way to open side water pick up for more easy flow . It is ok to run both open ?
07-14-2016, 06:38 AM #13Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
How much pressure do you have? At different rpm. Verify proper fuel delivery?
boby thanked for this post
07-14-2016, 10:21 PM #14Member
- Jan 2005
- Montreal Quebec
- 44
Problem solved.....more water pressure around 7 psi at idle ! There more.....I have no rpm gauge last year ( bad rectifier) and I notice that rpm fluctuations around 3000 rpm , 100-150 variations, back home remove plugs and the top one are white and the other one (7) are brown. Last year evinrure dealer clean carburetor . It is normal or not that the first carburetor mist a bleed just above the screw ?
St. Louis GP 1991..”Away he Wendt”..full Powerboat Magazine story.
By lars strom in forum Outboard and Racing HistoryReplies: 11Last Post: 04-25-2015, 10:26 PM -
Pennzoil full synthetic or klotz full synthetic?
By woundedwarrior in forum Technical DiscussionReplies: 16Last Post: 11-15-2012, 04:23 PM -
Oil tank on engine not completely full, oil alarm going off.
By syclone01 in forum Technical DiscussionReplies: 17Last Post: 07-21-2011, 12:47 AM -
no full power but no alarm
By arrowwaves in forum Technical DiscussionReplies: 4Last Post: 09-06-2009, 07:13 PM -
Mercury Tech: alarm
By extx in forum Technical DiscussionReplies: 2Last Post: 02-10-2009, 04:14 PM
