Results 61 to 75 of 84
Thread: New to me 23' Eliminator Daytona
10-18-2017, 03:24 PM #615000 RPM
- Sep 2017
- Saugatuck, Michigan
- 318
I would be curious to know....... I just purchased a 23 with twin 225's
08-07-2018, 10:58 PM #625000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
That would be me. A stock 23 hull will run the following speeds with the listed motors.
300 v8 65
twin 200 v6 80
After hull corrections
200 v6 80, super slow acceleration.
225 v6 87 medium slow acceleration
300 v8 100 , fast acceleration
300 v6 100, medium acceleration
08-07-2018, 11:02 PM #635000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
08-07-2018, 11:28 PM #645000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
The 23 is NOT weight tolorant. Twins make the problems worse. Your wasting your money if you don't get the weight out.
I know, I ran them with twin 200's, 260's and 400 v8's.
We have yet to see a properly setup twin 23. If you running 5 sheets of 3/4 inch sub floor glassed both sides and 500 pounds of interior your beating a dead horse. This is because of bottom flaws. You will have to get the weight out or alter the bottom or both. For twins the bottom correction is made to the outer sponsons starting 6 feet from the back and goes forward, it does not involve cutting the boat.
For a single engine DO NOT CUT the center pod. Been there done that. When done right the boat will run on JUST THE POD. If you get the weight out. I've run 22 Talon's , 21 Daytona's and most of the rest. The 23 Daytona is the best single runabout I've ever driven. When done right. It's bigger, more comfortable, takes more water and RUNS JUST AS FAST. When done right it will run 95 with one 300 Promax and FOUR adults. That's much faster loaded than the others.
It will NOT reach an acceptable level of performance STOCK.
Any questions?Last edited by tunnelfun; 08-07-2018 at 11:44 PM.
08-07-2018, 11:42 PM #655000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
08-08-2018, 12:35 AM #665000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
03-17-2019, 09:14 AM #676000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
Resurrection
This is one I just bought, don't have it here yet but trying to learn as much as I can about what to expect. https://m.youtube.com/watch?v=Z9yWEo7NdZQ
Watching the attitude and rooster, look's pretty good to me. What do you guy's think ? Thanks
03-17-2019, 03:50 PM #68
They ride flat don't require much trim I ran mine neutral or slightly neg and will go over 3 footers easy very stable boat we would go back to landing at 90 + all the tower /wake board , pontoons thought we were nuts
03-17-2019, 04:07 PM #695000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
23 Daytona
This is what they look like at 100 with a single 275 hp. If you look close you will see that the outside sponsons aren't doing a lot so far as lift.
03-17-2019, 04:24 PM #70
Holy set back!!! Was that a custom Gill Bracket?
engineermike thanked for this post
03-17-2019, 04:41 PM #715000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
No, 30 inch custom garage job. The boat runs the same top speed with 18 or 24 but the speed dropped from 95 down to 85 with a 4 person load. In order to punish the big supercharged outdrives on a 100 mile stretch in 2/3 footers with your buddies and two coolers on board you need the 30 inch. I watched a lot of those boats blow their motors trying to run with this boat on the long haul.
FMP liked this post
03-17-2019, 05:04 PM #726000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
03-17-2019, 05:32 PM #735000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
Mazco RE3, Chopper, Merc ET, OMC Raker...... They all ran the about same. Wouldn't run with a stock Bravo, at all. A power hog prop.
Fastest was a stock 15.5x32 Merc 4 blade clever. Ran 106 empty, but a loser under 90.
Best all said and done was a stock 15.5x31 Hydramotive Quad 4. Ran 102 empty and 95 loaded.
03-17-2019, 06:48 PM #746000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
What’s the logic behind all the setback?
03-17-2019, 08:39 PM #755000 RPM
- Sep 2010
- arkansas
- 142
- 19
- 31
That boat needs a 3% sponson attack angle to keep the boat dry, it wont run @ 2%. They will be wet. And -2% prop shaft angle to keep it from flipping when the nose lifts. 18 inches required positive trim, eliminating the case as a running surface. The boat uses a transom water pickup. Water contacts the back half of the case. When the nose lifts, the bottom of the case resist boat rotation. If the nose lifts more the case sinks and applies brakes. Going from no case to 3+ inches of case is a lot of drag in a hurry at 100. Very affective.
The 30 inch set back is necessary to balance the boat with 4 people and a full gas load.
At 18 or 24 set back it will run the top speed empty but only 85 loaded. With 30 inches it runs 95 loaded with the average prop.
Study the picture closely. The rear of the sponsons are almost clear of the water. The boat is riding on the center sponson and case. If the nose is run any lower the middle of the sponsons will get wet. The trim is negative. The spray from under the sponson is mist blown forward around the compression curtain and then dripping from the sponson chine edge. The compression can be seen on the water as far forward as the drivers seat.
27' Eliminator Daytona
By hobie79 in forum Hulls larger than 20'Replies: 3Last Post: 08-09-2014, 07:22 AM -
Eliminator Daytona 23 Ft
By dvracer in forum Hulls larger than 20'Replies: 2Last Post: 07-16-2014, 05:56 AM -
Eliminator Daytona 25'
By Rusty3 in forum General Boating DiscussionReplies: 1Last Post: 02-08-2012, 12:56 PM -
Eliminator 19' Daytona set up
By Allison's Allison in forum Technical DiscussionReplies: 15Last Post: 09-05-2002, 09:35 AM
