Results 16 to 30 of 84
Thread: New to me 23' Eliminator Daytona
07-28-2016, 11:53 PM #166000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Mine had triple engines on it at some point in time. I suspect triple 200's.
07-29-2016, 09:05 AM #17Member
- Mar 2006
- Boynton Beach, FL
- 74
- 13
- 18
Hydroskreamin, please do post them up. That would be great!
Thanks for verifying what I thought was going to happen regarding the hatch. I know I would lose a lot of light in there by closing it all up, but it sure would clean the lines up! Do you find the hatch useful now?
I would also like to see your refurbishing project. Do you have pics to do a before/after show'n'tell?Beer will not solve all of your problems... but neither will milk!
2005 Lightning 18' Action - 150 Optimax - SOLD
1982 Eliminator Daytona 23' - Twin 260's - SOLD
2012 Concept 32FE - Twin 300 Verados
07-29-2016, 08:58 PM #18
Glad you like, and it's nice to have some chatter with Eliminator guys. I have been looking hi and low for info on these for 3 years now. When the boat goes for interior, I will start a thread chronicling the 2 year process of this unit. It is an unconventional build, as it will be powered by a 400R, and I notched the center pod 6"x60". So yeah, I cut the bottom out of my boat. There's other stuff, too, I think you guys will like, we'll see. Trying to get the bulkheads and floor in so it can go for interior. I really want to splash this thing before the water gets hard here. Since I haven't used it yet (ever), I cannot comment on your hatch question. I'm looking for cabin ventilation from it more than anything. There will be a string of LED's along the top of the gunnel in the cabin for light, so I'm not too concerned about that.
If I get time this weekend, I will try to start a thread with the Eliminator brochures in the Photo&Video section, no promises.
Here is a pic before I started on it.
A problem is only a problem when viewed as a problem...
RikuY liked this post
07-29-2016, 09:48 PM #19
08-03-2016, 06:46 PM #20
Gents, I've started a thread in the Photos & Videos section with the catalog. Here's a link: http://www.screamandfly.com/showthre...06#post2881306
10-28-2016, 09:11 PM #216000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Took mine out today with the props turning in. Still porpoisong at 65 mph. Ugh....
11-07-2016, 07:12 PM #226000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Both HydroSkreamin and NICE PAIR have requested setup dimensions so I set it all up and took them today. I've noticed that some folks talk engine height from the bottom of the pod and others talk engine height from the sponson directly in front of the engine. I took the heights 3 different ways and here's what I got with the bottom of the sponsons level to the ground and prop shafts level to ground:
- Prop shaft centerlines are 1/2" above the bottom of the center pod.
- Prop shaft centerlines are 5/8" below the bottom edge of the sponsons (I didn't realize the center pod was lower than the bottoms of the sponsons).
- Prop shaft centerlines are 1 1/8" below the sponson, as measured directly inline with the lower unit.
I'm currently in the 2nd highest hole, so I can only raise them 3/4" from where they are without doing any major work.
11-07-2016, 07:37 PM #23
They look low to me, the 3/4" move up cost noting but some time, try it. I'm thinkin they still need to go UP.
Attachment 360230Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
HydroSkreamin liked this post
11-07-2016, 07:41 PM #24
11-07-2016, 08:14 PM #256000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
11-07-2016, 08:15 PM #26
It looks like if you moved the motors up 3/4" (putting the bolts in the lowest holes) there appears to be enough material @ the top of your motor plates to drill new holes @ the level of the top holes in the motor brackets.
That would allow you to start raising the motors 3/4" @ a time till you get up to 1 1/2" above bottom.
Attachment 360231Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
11-07-2016, 10:44 PM #27
my 23 center line 2" above pod on tunnel
11-07-2016, 11:21 PM #28
I agree!
EngineerMike, generally you use the dimensional difference of the propshaft centerline with drive level to boat bottom directly in front of the drive.
Another thing that I noticed after taking measurements on mine is that the center pod is not level with the sponsons; mine was 3 degrees down. This helps planing, but will also tend to drive the nose down, kind of like dragging a tab. I've always wondered if that is why you see so much positive trim in every picture you see of these things running fast. Most other center pod boats run near level or tucked at speed.
I'm also curious to see where your CG is.A problem is only a problem when viewed as a problem...
11-09-2016, 08:22 PM #296000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Ok, raised them to the highest hole. Now I'm measuring prop shaft centerline is 1 1/8" higher than the center pod and right at even with the hull directly in line with the engine. Still have to test though. I'm thinking about swapping my 24's out for my 30's also.
11-09-2016, 08:49 PM #30
I have no idea how much grunt the Yammies have but the Bravos hook up pretty good. You may have to put vent holes in the prop barrels to get it on plane. I run 1 1/4 vents on my 32 Bravos.
If you can borrow some vented 30's, that would be the ticket. (or 28's)
Get a reference on your trim, and know where it is when your testing, if you have to use a lot of positive trim, you may need different props or a new game plan. excessive + trim is not a cure. Good luck with your test.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
27' Eliminator Daytona
By hobie79 in forum Hulls larger than 20'Replies: 3Last Post: 08-09-2014, 07:22 AM -
Eliminator Daytona 23 Ft
By dvracer in forum Hulls larger than 20'Replies: 2Last Post: 07-16-2014, 05:56 AM -
Eliminator Daytona 25'
By Rusty3 in forum General Boating DiscussionReplies: 1Last Post: 02-08-2012, 12:56 PM -
Eliminator 19' Daytona set up
By Allison's Allison in forum Technical DiscussionReplies: 15Last Post: 09-05-2002, 09:35 AM
