Results 31 to 45 of 99
06-27-2016, 07:31 PM #31
06-27-2016, 07:38 PM #32
From the pics you posted, I'd bring the motor up 2inches to start.....it's sitting way too low.
.....and just to correct terminology for you, the plate above the prop is not a cavitation plate as most commonly call it, it is an anti-ventilation plate. Just in case you deal with a marina in the future that refers to its proper name1977 Hydrostream Vector 2.5 Promax
80's old school thanked for this post80's old school liked this post
06-27-2016, 08:17 PM #33
06-27-2016, 08:49 PM #34
06-28-2016, 09:38 AM #351977 Hydrostream Vector 2.5 Promax
06-28-2016, 02:11 PM #36Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Ok so I'm reading all this advice and most all of it is good.
I've built these Glen L boats and to me the transom was kind of a weak link. These boats don't have the strength in the transom area as a fiberglass boat does.
JMO but I wouldn't even consider putting a jack plate on it. Also it's a 16' boat! I don't think it needs any increased set back without adversely affecting the cg.
Again, just my opinion
You can definitely raise the engine but I would keep it bolted to the transom. Just raising it is going to put enough increased stresses on the transom.
06-28-2016, 02:27 PM #37
06-28-2016, 04:37 PM #38
I would bet money that if your fuel tank was empty and you had a small 6 gallon portable fuel tank in the back you would pick up speed. Usually a mid tank such as yours will cost you speed compared to a rear mounted tank in flat bottom boats. Might be worth a try.
Good luck, Carter
06-28-2016, 04:58 PM #39
I had wondered about the center mounted tank in this boat and it riding so wet. I have a 12 gallon tank in the back of my 16ft and keep going back and forth about a 13 gallon bow tank under the deck.
Now with the Optmax I also have the 3 gallon oil tank back there as well as 140 extra pounds of motor over the 125 Evinrude.
Karsten
Jimboat liked this post
06-28-2016, 06:40 PM #40Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
I would venture to say that the tank is mounted somewhere around cg and is not adversely affecting performance.
Do one thing at a time. Raise the engine one hole, which should be 3/4" if it's a standard BIA pattern, and test. First thing make sure you have good water pressure and try it. Then go the next hole and test, finally the last hole as long as water pressure, handling and speed are good.
You haven't mentioned what prop your running. Some stock type props won't surface well and might need to be changed out to see results. Choppers are great for performance but depending on boat use it might not be suited for the use. I.e. Wake boarding, tubing, etc.
06-28-2016, 07:06 PM #41
Are you still trying to sell your boat?http://inlandempire.craigslist.org/boa/5604428970.html
Hammer Down!
06-28-2016, 07:26 PM #42Team Member
- Lake Coochiching, Ontario
- 7,753
- 271
- 485
- 1571
- 6 Post(s)
A big ear chopper won't fit. Too big OD and his motor is 15 spline. A re hubbed small ear chopper would fit but I think the small ears have a lot less lift. What about a V4 Raker? 22 or 24?
06-28-2016, 07:38 PM #43
Not really, that ad should have expired by now. I was considering selling to possibly play with something new. What changed my mind was a good day at the lake at low altitude (Lake Elsinore)... Boat ran like an absolute gem and ran so much better than where I usually run her (Lake Arrowhead 5500')... and after that day, my wife and I could not let her go...
However now if I could possibly trade for a faster boat.... who knows!!??
For now, I will keep tinkering with what I got!Last edited by 80's old school; 06-28-2016 at 07:44 PM.
06-28-2016, 07:49 PM #44
06-28-2016, 07:55 PM #45
My boat had the Motorwell Modification done for Higher Horsepower engines.. I guess Glen L realized they had "weak" transoms. They issued a procedure for modifying for high HP.
I have posted the Modification Instructions in the following pictures...
Hopefully this helps in making a stronger transom..
Pro Boat Stiletto Tunnel
By Skeet 2 in forum Radio Contolled Performance BoatsReplies: 30Last Post: 03-14-2013, 07:26 PM -
Identifying boat make help needed please??
By rideordie in forum General Boating DiscussionReplies: 4Last Post: 04-17-2011, 08:28 PM -
Advice needed on jet boat
By chasnippen in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 07-22-2009, 11:14 PM -
10+ reasons to make your boat faster.David Letterman style
By raceboatrus in forum General Boating DiscussionReplies: 4Last Post: 12-06-2002, 09:30 PM
