Results 1 to 6 of 6
    Apr 2011
    Tampa, Fl
    2000 Mercury 250efi loud constant alarm
    I took the boat out yesterday and a loud constant alarm went off. I looked at the motor and it had a good stream coming out of the pee hole. It's a new boat to me. The temperature gauges weren't working but after tapping on the temperature gauge it started working and was at 150. After a few minutes the constant alarm went off. I headed back to my lift and as I was putting my boat on the lift the constant alarm came back on again.
    When thr the alarm first turned on the motor wouldn't go to WOT. It wasn't a beeping it was a very loud constant on alarm. Do these motors have inky alarms for overheat or low oil? Is the constant alarm an overheat alarm?
    Apr 2011
    Tampa, Fl
    I forgot to mention its 2 stroke, I topped it off with oil Before taking it out
    Apr 2011
    Tampa, Fl
    Anybody?
  4. Thanks futurePyro thanked for this post
    Might be water in fuel. Filter on motor has a sensor at the bottom. Un plug it and see if alarm stops. Also pull the filter and maybe change it if not done lately. No oil flow from oil pump also gives constant alarm. Is motor smoking?
    common problem with this motor is the check valve on starboard side of motor that supply air to oil tank in boat to push oil to tank on motor.
    Apr 2011
    Tampa, Fl
    [QUOTE=XstreamVking;2867678]Might be water in fuel. Filter on motor has a sensor at the bottom. Un plug it and see if alarm stops. Also pull the filter and maybe change it if not done lately. No oil flow from oil pump also gives constant alarm. Is motor smoking?
    it really wasn't smoking that I can remember. To be honest I didn't drive it too far after the alarm and didn't really notice whether it was smoking or not. I did a compression check and both motors and they all were within 10psi of each other.
  1. 2000 EFI 225 3.0L Merc SENSOR ALARM on fresh rebuild
    By 150aintenuff in forum Technical Discussion
    Last Post: 02-02-2015, 09:14 PM
  2. Mercury Tech: 1990 V200 Merc, constant alarm sound
    By wbones9 in forum Technical Discussion
    Last Post: 09-10-2014, 07:07 PM
  3. Mercury Tech: 2005 Mercury 150 constant BEEEP
    By fuxxy in forum Technical Discussion
    Last Post: 06-28-2011, 08:55 PM
  4. Mercury Tech: Help with constant alarm beeping
    By Riverrat0 in forum Technical Discussion
    Last Post: 07-21-2010, 07:33 AM
  5. Alarm Horn Not Loud Enough
    By 205pro in forum Technical Discussion
    Last Post: 01-07-2010, 08:52 AM
