Results 1 to 10 of 10
06-19-2016, 08:58 PM #1
Drive shaft and how far its seated into the crank.
I would like to lower my motor about 1/4". I am on the ragged edge and there is no way to lower my motor without cutting the transom. I would really hate to do that to find out I didnt like the results.
The lower unit I am running is 2-1/4" shorter than a standard lower unit. It made my 15" motor a 13-3/4" motor which is cool except I have zero clearance to lower it a little.
I would like to make a spacer to go between the lower unit and mid section. This would reduce how far my drive shaft seats into the bottom of the crank by 1/4".
Assuming its fully seated now, do you think that would be a problem?
I know I would have to extend the water tube and I think the shift shaft has enough meat to be okay.
21' Paramount
Mercury 300 Promax
06-20-2016, 05:06 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
It won't make any difference. Plenty strong for that lil boat and motor.
06-30-2016, 05:16 PM #3
06-30-2016, 09:41 PM #4
If all of your dementions are correct you will be fine!.
06-30-2016, 10:45 PM #5
that is one cool photo of the bullet above the water line
07-01-2016, 07:33 PM #6
where the heck is your water pickup?
07-05-2016, 02:20 PM #7
07-05-2016, 02:21 PM #8
You should be able to just cut your own out of some 1/4" aluminum plate. If you're good with a cutoff wheel, flap disc, and drill press, it's easy as pie.
07-06-2016, 10:42 PM #9
07-07-2016, 11:39 AM #10
Wear or damage on LU drive shaft to crank splines
By CircleHook in forum Technical DiscussionReplies: 3Last Post: 08-23-2015, 04:32 PM -
CLE lower Unit Good case busted input shaft or drive shaft
By CRLmotorsports in forum Lower UnitsReplies: 14Last Post: 09-25-2014, 06:13 PM -
Seized drive shaft in Crank???
By David Borg in forum Technical DiscussionReplies: 19Last Post: 03-13-2006, 04:48 PM -
Crank shaft drive shaft splines.
By gwalt584 in forum Technical DiscussionReplies: 5Last Post: 07-05-2005, 09:55 AM
