Results 1 to 2 of 2
06-16-2016, 10:00 PM #15000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
60* 150 getting water in cylinder
local guy comes in today.has 1992 150 eagle motor(60 degree block) mod -150glenc.lost #1 cyl.he rebuilt with new #1 sleeve,6pistons ,#1 new rod.had machine work done at reputable shop in Wisconsin.had block and heads surfaced flat.says they pressure tested head but still gets water into #1 cylinder.he thought water was coming in at thermostat area,and has some prob with thermostat seal.says it calls for HARD plastic seal but they used thicker/softer black rubber type and ended up cutting the soft one in half.I have not seen motor myself but it will be in on Saturday.my plan was to remove therm/and seal,and then run motor and inspect for water.thought maybe Racer or John Tiger or anyone else, could lend me their thoughts. thanx for all upcoming replys.-th
06-17-2016, 06:35 AM #25000 RPM
- May 2006
- 400
- 17
Remove the voltage regulator and look down at the casting for #1 cylinder for any seam openings, cracks, or pinholes.
Mercury Tech: 2.4 200 water in cylinder
By speedinstream in forum Technical DiscussionReplies: 8Last Post: 03-19-2010, 06:06 AM -
OMC Tech: water getting in one cylinder
By spearhunter7 in forum Technical DiscussionReplies: 11Last Post: 09-08-2009, 10:18 AM -
Water in Cylinder?!?!?!
By P man in forum Technical DiscussionReplies: 8Last Post: 08-21-2008, 01:54 PM -
water in the cylinder.
By Big Johnson v6 in forum Technical DiscussionReplies: 1Last Post: 03-11-2007, 08:36 PM -
HELP!!! Water in my #5 Cylinder
By wolf300tt in forum Technical DiscussionReplies: 12Last Post: 08-10-2001, 11:14 PM
