Results 1 to 5 of 5
Thread: 300x not peeing
    Oshawa, Ontario Canada
    300x not peeing
    This is a question for a friend of my. He has a pair of 300x on his new to him cat.One motor has normal water pressure and doesn't over heat but no water coming out of the cowl. What should we look at first!
    Jason
    18 Talon SOLD
    XR 2002 SOLD
    2011 STV RR 300pm SOld
    24 Skater 300xs
    stick a wire in the pisser make sure its clear
    Nov 2013
    United States
    Hit it with a blast from an air compressor in the pee hole and try again. Mine do it all the time.
    Massapequa NY
    If the preceeding posts do not do the trick, bring it to your urologist
    Mar 2012
    ANAHEIM HILLS, CA
    I drilled my pee hole out to make it wider, used to get clogged all the time with little pebbles and ****
  1. Supposed to be peeing from here?!?! Bizarre.
    By home made tunnel in forum Technical Discussion
    Last Post: 04-16-2016, 10:40 AM
  2. 300x Ecu
    By hydrostream1 in forum Misc. Parts and Accessories
    Last Post: 01-30-2014, 10:54 AM
  3. 300X oil
    By outboardrick in forum Technical Discussion
    Last Post: 04-30-2005, 08:16 PM
  4. No water peeing at idle, wot only 8lbs
    By RUNWME in forum Technical Discussion
    Last Post: 07-08-2003, 02:07 AM
