Results 1 to 3 of 3
Thread: Fuel pump problem...
05-30-2016, 01:45 PM #1Member
- Mar 2013
- Colo
- 49
Went fishing 4-5 days ago and everything was fine. This morning I launched at the lake and tried starting the boat and nothing. Turns out the fuel pump isnt turning on at all and my neighbors dog ate my good manual so the one im left with is a generic one for multiple years and models, add to that Im pretty dumb when it comes to this stuff and I cant figure out how to test it.
The outboard is a 1996 Mariner 200 EFI
I have 12.6 volts to both terminals at the top of the pump.
The manual says to ground out one side and check for voltage. One wire is red the other is black with a red stripe and I dont get the "ground a wire" thats hot part.
Any help is appreciated.
05-30-2016, 02:44 PM #2Member
- Mar 2013
- Colo
- 49
Update..
I grounded it out then the pump runs fine.
05-31-2016, 05:38 AM #3Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Fuel pump driver is bad in the ecu. It provides ground when the key is on. You can wire around it with a toggle switch that provides ground
Erik Kiser
Mercury Tech: Pro Max ECU/fuel pump Problem
By Go Time in forum Technical DiscussionReplies: 7Last Post: 04-18-2012, 08:55 AM -
Mercury Tech: Possible ECU problem with fuel pump driver
By BigE in forum Technical DiscussionReplies: 6Last Post: 06-20-2009, 11:45 PM -
225 promax problem w/fuel pump
By STVRacing in forum Technical DiscussionReplies: 0Last Post: 09-13-2005, 06:43 PM -
Fuel pump problem
By Liberator in forum Technical DiscussionReplies: 6Last Post: 06-02-2004, 07:51 PM -
Holley fuel pump problem??
By 87vantage in forum Technical DiscussionReplies: 3Last Post: 04-23-2003, 07:40 AM
