Results 1 to 5 of 5
05-23-2016, 07:57 AM #1
Dual temp gauges issue OR engine Issue
Good day to all,
I installed two temp gauges on this 3.0L V6 engine last year but did not have a chance to really see how they behaves.
Now yesterday, I went for a gentle ride about 3500 rpm and notices that theright head keep itself at 150* and the left one is slightly warmer under all conditions.
Is it prone to tell me that the jetting might be too lean on this side thus keeping the heads warmer ?? or is it something else. water flow and pressure is good ( 7psi all the time )Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
05-23-2016, 10:37 AM #25000 RPM
- May 2014
- NH
- 170
- 27
- 37
- 16
On that engine which bank is higher? Assuming the sensors are in the exact same place, usually the higher placed bank is a little hotter. On most engines I've had that's the starboard bank but never studied what you've got there.
Slightly different is kinda normal, something as simple as a difference in the sensors, gauges, or wiring will give you 5 degrees - nevermind a difference in thermostats or something else on the engine. If you are concerned you could start swapping things around and see what you find, and/or use a temp gun to take a consistent reading.
I had twin engines w/ analog sensors in each bank for awhile (ie 4 gauges to watch and drive you nuts) and eventually what I learned was they never run at the same temp but when you start seeing a larger difference it's time to check.
Jon
05-23-2016, 05:38 PM #3
Good day,
I measured the lenght of both wire because they are the same lenght, Both sensors were measured with the same water temp to make sure I was not gonna guess but I still do.
Swapped the meters and sensors, still port side is warmerGlastron GT 150 W OMC 140
05-23-2016, 07:42 PM #4
Through the years I've found that few gauges read exactly alike. Switch the sending units on the gauges and see what they read!
Most gauges are nothing other than Smart Idiot Lights!
05-24-2016, 09:37 AM #5
I've swapped the gauge4s and/or the sending unit and the readings remain the same. the port head is warmer than the starboard side
WillySteve liked this post
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
Mercury Tech: Water Temp/Engine Temp Gauges
By FisherBoats in forum Technical DiscussionReplies: 2Last Post: 04-11-2012, 08:29 PM -
Mercury Tech: 2.4 200 water temp issue
By Hunter Thompson in forum Technical DiscussionReplies: 5Last Post: 08-05-2011, 07:22 PM -
water temp/pressure issue on a 225 pro max
By John Dorn in forum Technical DiscussionReplies: 7Last Post: 08-02-2011, 05:27 AM -
Gaffrig Water Temp Issue
By That's Right in forum Technical DiscussionReplies: 4Last Post: 05-03-2011, 02:55 PM
