Results 1 to 8 of 8
Thread: 1983 mercury blk max 150hp help.
05-12-2016, 07:24 PM #1Junior Member
- May 2016
- Hee Haw,S.C
Newbie here,I was wonder what year lower units are interchangeable with this year motor cause i broke my main shaft in the lower unit down by the pinion gear. thanks steve.
05-12-2016, 08:47 PM #2
If your changing the whole lower,most any of the 2L 2.4 and 2.5 will fit. Just be sure the shaft length and gear ratio are the same.Your 83 is most likely what's called a preload style,witch is the weakest of the lot.The pinion spline and pinion bearing in that one is also the smallest.
05-12-2016, 09:47 PM #3Junior Member
- May 2016
- Hee Haw,S.C
thanks outasite, what years was the 2L 2.4 2.5 made in? i have a friend that can get me a lower unit but he thinks it a 90 model blk max 150
05-12-2016, 10:08 PM #4
Any v6 from 1976 up as long as it's 2.0 2.4 2.5 through at least 2003
smackie017 thanked for this post
05-12-2016, 10:13 PM #5Junior Member
- May 2016
- Hee Haw,S.C
ok thanks. what year would be my best bet to get as a upgrade?
05-13-2016, 12:34 AM #6
Get the case from your buddy done deal.
05-13-2016, 08:24 AM #7
You have the worst one,so anything else is an upgrade.IMO the best fish case, is a big bearing ratchet style.But as Dave said, just grab one and go!!
05-15-2016, 06:58 PM #8Junior Member
- May 2016
- Hee Haw,S.C
well the lower unit my friend say he could get wasn't what the guy said so now i'm in need of a lower unit i measured my shaft from the lower bearing to the top of the pin at the end of the shaft and its 25 inches long. does this sound right? forgive me for being a newbie but i do want to learn.
1983 Mercury 115 HP inline six?
By Brian B. in forum Technical DiscussionReplies: 4Last Post: 03-13-2016, 01:14 AM -
1998 mercury 175hp on a 1989 mercury 150hp midsection
By TyElrod in forum Technical DiscussionReplies: 13Last Post: 01-29-2014, 02:23 PM -
Evinrude E-TEC 150hp DI vs Latest Mercury 150hp 4 stroke
By LIQUID NIRVANA in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 35Last Post: 02-07-2013, 08:18 AM -
Mercury Tech: 1983 150hp WH-31 main jet size
By baja200merk in forum Technical DiscussionReplies: 1Last Post: 06-29-2012, 06:55 AM -
1983 Mercury 80 HP inline
By papermouth in forum Technical DiscussionReplies: 0Last Post: 04-10-2007, 10:43 PM
