Results 1 to 4 of 4
05-05-2016, 08:14 PM #1
Throttle linkage on 200 efi stock 2,4
ILL try to explain best i can engine at idle plastic cam is not touching roller that opens air mass butterfly about 3/8 away, so when i push throttle to accelerate only timing moves for first inch then cam contacts efi roller. saw on utube as soon as throttle moved cam on end of rod moved roller almost immediately open big butterfly motor runs great wot but kinda ratty mid idle etc that ss rod has a slight bend but looks intentional/ its a 1988 220 xri is that linkage slack correct? cant find a good side photo to compare any comments welcome thanks ART
05-07-2016, 08:16 PM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
Cam roller is adjustable it can be moved closer or further away via the Phillips heads crew on the linkage apparatus
Dave Strong liked this post
05-08-2016, 11:28 AM #3
Sounds like you need a service manual, would not be playing with it till you do.
TEXAS20225 liked this post
05-08-2016, 05:35 PM #4Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
Dave X2 i think someone mentioned that allready last year
OMC Tech: throttle linkage
By bulldogdaddy in forum Technical DiscussionReplies: 10Last Post: 05-27-2011, 11:00 PM -
Mercury Tech: Throttle linkage
By ctered in forum Technical DiscussionReplies: 1Last Post: 07-21-2010, 07:46 AM -
Throttle linkage help?
By whipper in forum Technical DiscussionReplies: 2Last Post: 10-20-2007, 11:02 AM -
Johnson throttle linkage not fully pushing down carb linkage
By NicePackage in forum Technical DiscussionReplies: 4Last Post: 05-28-2006, 07:36 PM
