Results 1 to 1 of 1
Thread: Voltage Regulator or Rectifier
05-05-2016, 12:14 PM #15000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
Guys:
This is a bit of a repeat post, but I have a photo of the issue in question now. The motor is a 1989 80 HP (3 cylinder). Voltage gauge on dash reading 17 volts.
Please see photo: Is this the rectifier or the voltage regulator? Second, in the photo you'll see a black wire (on left side of unit, with a terminal ring) that's hanging freely...should this be grounded/attached? Basically, why are we seeing 17 volts?
Thanks to those that responded to my earlier post and to this one!!!
CDI or OEM regulator/rectifier??
By seef158 in forum Technical DiscussionReplies: 3Last Post: 06-25-2015, 09:38 PM -
Stator voltage regulator rectifier question 2.5 260
By oper600 in forum Technical DiscussionReplies: 5Last Post: 05-08-2013, 04:13 PM -
3 cylinder Merc 75-Rectifier/Voltage Regulator
By WillyT in forum Technical DiscussionReplies: 1Last Post: 07-12-2001, 06:28 PM
