Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Jun 2019
    Tortola, British Virgin Islands
    Need some help propping my 22 Activator. I have on a 300xs Optimax with a sporty 1.75 mid, 8" setback. What's the best prop for a circuit race for this setup? Then what would be the best speed prop.
    Thanks for your help
  2. #17
    Apr 2017
    Pomona ny
    Bravo 1 or a pro max
  3. #18
    Sep 2007
    Rochester, NY
    While we are on the theme of 22 Activator set ups. I have a 03 with the notch. It has a16” stainless marine bracket. Last year I was running a 2.5 200 on a 4” jack about 2” above the pad. Boat was a bit hard to plane off but balanced and ran very smooth. I repowered with a Yamaha 300 Hpdi and rigged it on the bracket 1.5” below the pad
    I have to give a ton of trim to get the nose up and it wants to bow steer. I have tons of water pressure 20-25 psi. I have tried a28p bravo 1 way too much stern lift and bow steer scary bow steer. A 25p ballistic 4 blade that ran decent but needed lots of trim and I was on the limiter. 71 mph then I spun the hub. And a 28 mazko re again needed a ton of trim but could get it aired out at 73 but only 5500 rpm.
    My thought was the the the heavier motor would need less set back and engine height. As it would help carry the bow. Next I’ll try bringing the motor up a couple holes and see how that does. Maybe pick up a trophy prop as a tester as they seem to run well on these boats. My buddy has a hydromotive quad 4 26p I can borrow but not sure that will get the bow lift I need.
    I have ave a 6” hydraulic jack plates I can try to bring the motor back. But that may be a bit far. But would allow me to mess with engine height, or pull the bracket off and start with 6” set back and work my way back.
    Thoughts??
  4. #19
    Sep 2017
    Miami
    Does anyone know where the Yellow 22 Activator with the white bottom "intense" ended up? Who has it now ?
  5. #20
    Feb 2019
    Plainview, NY
    i spoke to the dude who owns it i think it was in CT? i dont remember
  6. #21
    Sep 2010
    long island,ny
    Quote Originally Posted by Dannus View Post
    They are nice wave handlers but most are bow heavy. I had a 1990 and took out the front bow stringers and replaced with short ones and glassed the front area with coring. Then I added transom supports and ran a Yamaha 250 OX66 on a 18'-21' setback. Ran strong 82-85 with a Spinelli 29 4 blade. Also ran good with a 28 solas S3. Motor was 1.25" below bottom.
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  7. #22
    Apr 2017
    somers point, new jersey
    Quote Originally Posted by jcoop421 View Post
    boat is in Cambridge MD
  8. #23
    Apr 2017
    It’s been in storage for several years in MD.
  1. Activator 27
    By fobe in forum General Boating Discussion
    Last Post: 11-16-2016, 08:39 PM
  2. 22 activator
    By c10stuntin in forum Props, Setup, and Rigging
    Last Post: 03-28-2016, 08:05 PM
  3. Activator 27
    Last Post: 03-13-2011, 11:14 AM
  4. Activator
    By zachp13 in forum General Boating Discussion
    Last Post: 12-14-2007, 02:27 PM
  5. 22 activator 300 pro max?
    By alpharacer1 in forum General Boating Discussion
    Last Post: 06-22-2004, 02:34 AM
