Results 1 to 15 of 23
    Apr 2016
    SomersPoint
    22 Activator 300xs
    Need some help propping my 22 Activator. I'm putting a 300xs Optimax with a sporty 1.62 mid, 10" setback jackplate. What's the best prop for overall performance for this setup? Then what would be the best speed prop.
    Thanks for your help
    John
    Feb 2003
    Bellingham, WA
    John,
    What "performance" is your goal? Top speed or rough water handling.
    Also, does your Activator have a notch in the transom?
    22' Activator w/ 250xs Merc Opti, back home again
    Apr 2016
    SomersPoint
    Quote Originally Posted by blkmtrfan View Post
    John,
    No notch, rough water handling
    Feb 2003
    Bellingham, WA
    Your setback should be about right with the weight of the 300xs.
    My favorite rough water prop was a 4 blade trophy, an older one, full diameter barrel, but new enough to have the hub style prop so it was usable with the fat shaft.
    The small barrel trophy plus is good too, just not the one I liked best.
    Hope that helps a bit....
    Any pics of your setup?
    Apr 2016
    SomersPoint
    No not yet. Work in process.
    Feb 2003
    Bellingham, WA
    No problem,
    Ask me anything, I owned mine for over 10 years, first rigged it with a 2.5 liter 280 and then with a 250xs with a setup more towards rough water handling and cornering.
    Apr 2016
    SomersPoint
    Thanks
    I think you might be better off with a 1.75 gear ratio if you have a choice.JMO
    Apr 2016
    SomersPoint
    All ready on its way.
    Thanks
    Apr 2016
    SomersPoint
    Where do you find it best for motor height for running?
    Jan 2007
    lindenhurst
    Is it the yellow 22 that was on long island?
  12. #12
    Apr 2016
    SomersPoint
    Quote Originally Posted by mikeylarge View Post
    yes
  13. #13
    Prince George B.C. Canada
    I would also talk to Todd at Hydromotive 330.425.4266/3629. In the past couple years he has developed a prop for the Big Barge Allison XB 21 fter at 1400 lbs. After testing lots of different props and styles he has come up with one that propels the big bass boat to 97.5 mph with only a stock 250xs. Water temps were 90 deg!! Also that was only one run testing. Hears a clip showing not only the run and gps speeds in the boat but how loaded with gear the boat was being tested. It had excellent hole shot and over all great manners at all speeds up to 100 mph. i would think that prop would be an excellent choice for any larger vee Hull with the XS motor setup. Very stout well made option. Todd also has a very good customer satisfaction policy. Im sure if you talked to him he would be happy to work with you on achieving your goals. https://youtwww.youtube.com/watch?v=2p3HD3ItC6Qu.bp3HD3ItC6Q
  14. #14
    Jan 2007
    lindenhurst
    Quote Originally Posted by Intensejohn View Post
    yes
    That boat runs a little funny. Keep the setback as small as you can. You will see why
  15. #15
    Sep 2010
    long island,ny
    I know that boat, 175 gears would be better I agree as mentioned above though see how it runs first with what you have to start with. I recall that boat did best all around with a Bravo XS wheel or a large barrel Hydromotive 15" as it likes/needs alot of lift.
    GL
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  1. Activator 27
    By fobe in forum General Boating Discussion
    Last Post: 11-16-2016, 08:39 PM
  2. 22 activator
    By c10stuntin in forum Props, Setup, and Rigging
    Last Post: 03-28-2016, 08:05 PM
  3. Activator 27
    Last Post: 03-13-2011, 11:14 AM
  4. Activator
    By zachp13 in forum General Boating Discussion
    Last Post: 12-14-2007, 02:27 PM
  5. 22 activator 300 pro max?
    By alpharacer1 in forum General Boating Discussion
    Last Post: 06-22-2004, 02:34 AM
