Results 1 to 15 of 15
04-22-2016, 07:12 PM #1
Member
- Apr 2015
- Lonoke
- 78
Mercury firing in 2 cylinders same time
I have been trying to figure out my mercury 40hp 4 cylinder 2 stroke for a wile now And I can't seam to figure it out I have replaced stator, trigger and switch box so far motor starts up and idles great but now it bogs down and acts like it has no power so checked timing and noticed when I hook light up to #3 I don't get much of a flash it pretty much just stays on when I hook up to 1 2 4 they all flash good. So I marked Top dead center on my flywheel for all 4 cylinders and checked each cylinder individualy and 1 2 4 all only show it firing on the cylinder I am hooked to but when I hook to 3 it showes to be firing on 3 and 4 at the same time. Is this normal? And if not what do I do now?
04-22-2016, 10:31 PM #2
Member
- Apr 2015
- Lonoke
- 78
Could a bad rectifer regulator cause this issue? It is the only thing I have not reaced. I did unhook it from the stator and ran it on a water hose but still was firing 3 and 4 at the same time.
04-22-2016, 11:28 PM #3
Got to be in the switch box.wires hooked up properly in accordance with color code? I don't believe it could possibly be the rectifier.
04-23-2016, 02:16 AM #4
5000 RPM
- Mar 2006
- auckland new zealand
- 687
- 9
- 7
- 15
What 40hp do you have? late model jap one?
04-23-2016, 07:55 AM #5
Member
- Apr 2015
- Lonoke
- 78
04-23-2016, 07:56 AM #6
Member
- Apr 2015
- Lonoke
- 78
04-25-2016, 02:54 AM #7
Swap out flywheel i had one go bad. Drove me nutz
04-25-2016, 04:52 PM #8
Member
- Apr 2015
- Lonoke
- 78
Is there any way to see if it is a bad flywheel? As I don't have one to try
04-25-2016, 09:50 PM #9
04-26-2016, 06:12 PM #10
Member
- Apr 2015
- Lonoke
- 78
04-26-2016, 08:58 PM #11
Member
- Apr 2015
- Lonoke
- 78
Ok I figured it out had a old switch box laying around so I stuck it on there and what do you know it fires just as it should. Hopfully it runs good but wont know for sure untill I take it to the lake. Can't believe I had 2 bad brand new switch boxes what are the chances.
davemvegas liked this post
04-26-2016, 09:29 PM #12
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
WHat brand boxes ?
04-26-2016, 09:37 PM #13
Member
- Apr 2015
- Lonoke
- 78
04-27-2016, 07:06 AM #14
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
CDI , which makes a great product told me a couple years ago to be careful of knock off components that very closley resembled the original . Even some of the packaging was near the original with style and colour.
04-27-2016, 07:20 AM #15
Member
- Apr 2015
- Lonoke
- 78
Mercury Tech: 1998 Mercury 90 hp firing erratically
By moldman in forum Technical DiscussionReplies: 11Last Post: 11-27-2013, 01:08 PM -
Merc V200 Not Firing on all cylinders!!
By fmeroney in forum Technical DiscussionReplies: 32Last Post: 06-03-2011, 08:58 PM -
OLD Mercury 125 Inline multiple firing
By dynobo in forum Technical DiscussionReplies: 5Last Post: 03-18-2011, 04:14 PM -
OMC Tech: 3 cylinders not firing
By Hazard in forum Technical DiscussionReplies: 17Last Post: 07-29-2008, 02:49 PM -
mercury 115 in-line 6 firing help
By Javelin409B in forum Technical DiscussionReplies: 8Last Post: 05-22-2008, 01:59 PM
