Results 1 to 14 of 14
04-19-2016, 11:25 AM #15000 RPM
- Feb 2012
- Prospect, KY
- 115
- 32
- 14
Clogged Fuel Line??? Difficult to pull fuel through fuel line.
The ball seems to work. It does pull fuel and pump it to the fuel pump. But not very much. It's a new ball. But when I press it in it likes to stay in.
Tried to Linda Lovelace the line myself and found it to have a significant amount of resistance.
If there was an air leak then it would pull air and inflate the priming ball. I removed the fuel tank cap to see if it was a vent issue but still having difficulty getting it to allow fuel to come out.
Got any suggestions on what I can do or check?
rgsauger liked this post
04-19-2016, 01:13 PM #25000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Pinched, twisted or folded fuel line- I had one get pinched under the floor-
Anti-siphon valve clogged
Has it been sitting up?
Also had a gas line de-laminate inside-
Can you get to tank outlet fitting?
supervetteracer thanked for this post
04-19-2016, 01:28 PM #35000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
anti siphon valve(last fitting on tank)remove ball/spring/ballseat from inside of hosebarb fitting. clogged pickup tube in tank..if you have old gray merc fuel line (red printing )replace it-th
04-19-2016, 02:14 PM #45000 RPM
- Feb 2012
- Prospect, KY
- 115
- 32
- 14
Working in a very tight area to try and get to the anti siphon part. Can't seem to get a 1 1/4 wrench to grab at thsi angle. Guessing I need to remove this assembly and check it.
04-20-2016, 07:46 AM #5
If you have the grey colored fuel line get it all out of the boat. It is not ethanol safe and has caused a lot of problems. The inside of the hose breaks down and cloggs everything up.
21' Paramount
Mercury 300 Promax
tux974 liked this post
04-20-2016, 06:55 PM #6Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 490
If your engine has a VST tank on it (Merc) Promax+ check it for debris in it and/or just go ahead and drain it and clean it out once you drain your fuel line and replace it.
I am going back with a new squeeze bulb and Trident Barrier Lined A1-15 Fuel Hose USCG approved - 3/8 Inch fuel line and making up my own new setup to length. Hopefully when I have it out, I can shoehorn and fish my SC1000 connectors through the tube.
I hear the best line to use is the blue stuff Hoser sells.
04-21-2016, 12:38 AM #75000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
have had nothing but problems with all primer bulbs EXCEPT-- BRP EVINRUDE brand-- install at least 25 every season--install with arrow pointing up-th
04-21-2016, 05:35 AM #8
My Bet is with Chris. Ethanol has deteriorated the fuel hose.
04-21-2016, 09:05 AM #9Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 490
04-30-2016, 01:15 AM #10Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 490
OK just got in the BRP brand yesterday. Hope to get back working on the boat this coming week. Thank you.
04-30-2016, 05:35 AM #11
No grey stuff, Quicksilver primer bulb with arrow pointing up has always worked well for me!
04-30-2016, 07:55 AM #12Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 490
I like that blue hose you run. That is the awesome stuff. When I go through the Shadow next, I will be using that. I used the Trident A1 USCG approved stuff in the Intimidator next go around with it, I get the blue as well.
04-30-2016, 08:52 AM #13
04-30-2016, 09:08 AM #14Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 490
That is what the Trident is, USCG approved. No auto part house High Pressure FI hose I have seen is USCG approved.
Mercury Tech: Best fuel pump location and fuel-line set-up for my HST
By 15 Mustang in forum Technical DiscussionReplies: 11Last Post: 06-16-2009, 07:16 AM -
Fuel Return Line - Rigging New Fuel Pump Setup
By Hydrasports205 in forum Technical DiscussionReplies: 10Last Post: 06-17-2005, 07:06 AM -
Fuel Line Size & Fuel Filters
By Liberator21 in forum Technical DiscussionReplies: 2Last Post: 09-26-2004, 08:50 PM
