Results 1 to 5 of 5
    Apr 2016
    Hiram Georgia
    1994 200hp mercury efi
    It would run good when I first started it then in 5 min start running bad then I could wait for 15min it would run great all day next day I cranked it on muffs and it ran good for 5 min that started running bad I shut it off and started pulling plugs and they were milky looking worst on bottom cylinder
    Mar 2011
    Virginia
    milky sounds like some water is getting in the combustion chamber....could be coming in with fuel or leaking in from a crank in block coolant passges, I doubt a head gasket would do this as it would probably inject air into the coolant.
    Go Time
    26 Regulator twin 250 EFI
    Jul 2002
    FT WORTH, TEXAS
    look at the exhaust divider plate on the back of the motor its the main culprit maybe base gasket but not likely
    Apr 2016
    Hiram Georgia
    Quote Originally Posted by TEXAS20225 View Post
    That's what i thought but had to hear it from someone eles thanks
    Apr 2016
    Hiram Georgia
    Well I replace head gasket and exhaust plate gasket and its still doing the same thang I'm guessing power head and exhaust gasket next only thing it runs bad when I first crank it and check the plug there milkey looking not all of them just 3 or 4 I can run it till it gets warmed up and it runs good and the plugs aren't milkey looking
  1. 1994 Mercury XRI 200hp Engine mods?
    By blowitup in forum Technical Discussion
    Last Post: 08-25-2011, 11:06 AM
  2. 1994 2.5 200hp mercury cowls
    By chaudron in forum General Boating Discussion
    Last Post: 08-20-2008, 07:04 AM
  3. model #-1994 200hp Johnson Venom?
    By baja200merk in forum Technical Discussion
    Last Post: 11-12-2004, 09:42 AM
