Results 1 to 13 of 13
    Mar 2016
    NSB, FL
    New 300XS owner with questions
    I was referred to this forum based on my search for information on my new to me 2007 Mercury 300XS Optimax that is on the back of my Shearwater Bay Boat. From my initial research it seems that these motors are pretty reliable, the motor has just over 200 hours. What issues should I be aware of with this motor. I was told to run either Rec 90 or Super 93. Where can I get a service manual for this motor, as Mercury as it listed as NLA? Where is the best place to get parts on the internet? I've noticed that this motor has many different options for the lower unit, I do I tell which one I have? I'm pretty handy, so I do like to perform my own maintenance (lower unit oil change, impellor, filters, etc.) and leave the tech items that are above me to the experts at my local Mercury dealer. Any guidance is greatly appreciated.
    Aug 2012
    Tenkiller Lake, OK
    Mercury Service Manual part number is: 90-8M8020345 I think that they are still available. They are pretty reliable once they get thru their initial shake down. Some have had air pump and coil issues. Run 91 R+M/2 non-ethanol gas. Mercury has a new 2 stroke oil #8M0078011 that is recommended for the 300SX. Also a new gear lube #8M0078016 for Sport Master gear cases or any HP use. There are Sport Master and Torque Master gear cases available on 20" and 25" mid sections. Sport Masters are unpainted with low water pick-ups. Torque Masters are painted black. There is also a service manual for the gear cases #90-842009. Working on them is really straight forward and the manuals are really good. I have been on a steep learning curve with them. I don't know it all, but if you have a question, PM me and I'll try to help. David
  3. Thanks MeCapnDave thanked for this post
    Likes SUNKIST liked this post
    Mar 2016
    NSB, FL
    Quote Originally Posted by Davidlake View Post
    Thank you, I will definitely PM you with any questions. I have the Sport Master gear case
    Mar 2016
    NSB, FL
    those numbers work, found the manual on Amazon
    Sep 2012
    Las Vegas
    Merc says some ethanol is OK for this, i forgot the percentage.Most important thing: NEVER let the gas go bad from storage. They are sensitive to getting plugged injectors, both air and fuel. Run Starbright Startron or Stabil Marine, or whatever you like. And make sure you last run already has the preservative in it, so anyresidual fuel in the motor will have the additive in it.
  7. Thanks swaddict thanked for this post
    Gothenburg, Sweden
    Quote Originally Posted by swaddict View Post
    The most important piece of guidance you can get is not to assume that the guys at your local Mercury dealers are tech experts.
    Jul 2009
    West Coast, FL
    I am very surprised they put a SM on a bay boat. Was it rigged this way or was it repowered?
    Mar 2016
    NSB, FL
    Quote Originally Posted by dogeatdog View Post
    it was rigged this way
    Sep 2012
    Las Vegas
    I just saw on Merc website that up to 10% ethanol is OK for 300xs. Still very confusing though on which oil they recommend as best for it.
    Aug 2012
    Tenkiller Lake, OK
    Quote Originally Posted by Sleek Jr View Post
    See post #2 for Mercury Racing two stroke oil. That is what Mother Mercury recommends.
    Sep 2012
    Las Vegas
    Oh I guess that's their NEW recommendation? I just looked in both my factory Merc manuals for a 2007 300xs, and they recommended Premium Plus in both, and said "If Quicksilver oil is not available then be sure to use a TC-W3 rated oil".
  14. #12
    Aug 2012
    Tenkiller Lake, OK
    Yes, There was a Mercury Tech Bulletin for it.
  15. #13
    Sep 2012
    Las Vegas
    I'm finding that the new "Mercury Racing" oil 8M0078011 is kinda hard to find and way more expensive than Premium Plus. Also just read over on BBC forums that this new oil should never be mixed in the oil tank with ANY of the older types.
    Also there is some debate that if you're not using your 300XS like a "race" motor (extended high rpm WOT), but spend a lot of time low RPM, fishing, trolling etc, you might be better off running the DFI or Premium Plus oil.
    If anyone finds a good source to get the new oil at a reasonable price, please post here.
  1. Reaction 19 questions for new owner, set up, suggestions on restringing hull
    By syclone01 in forum General Boating Discussion
    Last Post: 09-08-2014, 11:59 AM
  2. 300xs questions
    By Paramount 21 2007 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-03-2011, 08:58 PM
  3. Mercury Tech: New Hydrostream Owner & First Time Outboard Owner Questions
    By TripleJackInGA in forum Technical Discussion
    Last Post: 06-19-2009, 02:59 PM
  4. Mercury Tech: new 1999 xr6 150 owner questions
    By shawn880 in forum Technical Discussion
    Last Post: 10-12-2008, 07:55 PM
  5. First-Time Jet Drive Owner w/ Questions
    By TripleJackInGA in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-02-2008, 01:14 AM
