Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 75
  1. #46
    Jul 2011
    San Diego
    ...Click image for larger version.
ID:	343269Click image for larger version.
  2. #47
    ST.PETE FL.
    5 Thread(s)
    looks killer great job!
    SEEBOLD CHAMPBOAT MERCURY S3000
  3. Thanks greatwhite85 thanked for this post
  4. #48
    Jul 2011
    San Diego
ID:	343506Click image for larger version.
ID:	343507Click image for larger version.
ID:	343508Click image for larger version.
ID:	343509Click image for larger version.
ID:	343510Click image for larger version.
ID:	343511Click image for larger version.
ID:	343512Click image for larger version.
ID:	343513Click image for larger version.
ID:	343514Click image for larger version.
ID:	343515Click image for larger version.
ID:	343516Click image for larger version.
    ...and the first mock up.Click image for larger version.
  5. #49
    Jul 2011
    San Diego
    Not much happening lately, just fine tuning everything again. I finish sanding all the original paint off, and block sanded all the facets with 150. Still have a few spots to touch up. I made a front cover (�� David) with plywood and mounted it with four screws
ID:	343810Click image for larger version.
    I will seal the wood with a coat of "bar-top" epoxy before primer and paint.
    All that's left to do for bodywork is to make the centerpiece for the false NACA ducts, or as I have been calling it "the vent wings. I will cut it out of 1/4 inch poplar and probably cut it with Epoxy or filler before I have my buddy "JB" "weld" it in, and because I like overkill I'll throw in a few screws from the inside. Once I blend the corners in it will be ready for the first coat of epoxy primer.
  6. #50
    Jul 2011
    San Diego
    Was supposed to be a Symbol for you David.
  7. #51
    Jul 2011
    San Diego
ID:	344003Click image for larger version.
ID:	344004Click image for larger version.
    I set a 1/4" ss bolt on the top rear of the engine ( in the bolthole that used to hold the bracket for the old cowl, dabbed a little epoxy on the headof it then set the new cowl in place. After which i braced the bolt with an aluminum bracket and epoxid the crap out of that. Now I have a rigid firm "pin" that lines up perfectly at the top. There is about a quarter inch gap between the base of the "pin" setup. A few rubber washers Will allow the Cowl to slightly rest on it taking a load off the bottom pan. I think that should be enough support for this. I don't know, maybe I'll set the front side the same way to
  8. #52
    Jul 2011
    San Diego
    Made The center pieces for the "vent wings" with 1/4 inch poplar and shaped it before I epoxied it into place. Although Epoxy itself is probably more than strong enough I went ahead and drilled holes along both sides to allow the epoxy to seep into ( I know, it's ridiculous) and of course I'll throw in a few small screws underneath it to further overkill on top of my overkill just in case some fool tries to use it as a handle and snaps it off I want to know it's not because I didn't bond it good enough.
  9. #53
    Quote Originally Posted by greatwhite85 View Post
    They have medicine for that now.
  10. Likes greatwhite85 liked this post
  11. #54
    Jul 2011
    San Diego
    So I guess I lied... About the 5 intake vent holes on the top. At first I didn't mind (that they were bigger) but the more I looked at it the more it bugged the sh!t out of me. The way it looked stretched across too far ( was more like 1" than 1/2") seemed to throw off the dimensions and I know i'm the only one who would think that. Maybe I really am crazy! But it wasn't very hard to fill a couple of holes in. It took about 10 minutes of work with 20 minutes of wait time. So now I have four vents holes instead of five and I'm glad I did it. In looks much better to me, and the engine was still breathe just fine. I've seen earlier models of these Cowls with 3,4 and 5 vents.
ID:	344384Click image for larger version.
    Epoxy primer is next!!!
  12. #55
    Jul 2011
    San Diego
ID:	344462Click image for larger version.
  13. Likes David - WI liked this post
  14. #56
    Very cool... I was kind of doubting it would be possible (that you would end up with just a pile of jigsaw pieces) when you started - but it looks awesome.
  15. Thanks greatwhite85 thanked for this post
  16. #57
    Pekin, IL
    So now that you have one under your belt I would like to send you maybe 15 or 20 old clamshell cowls to convert. You OK with that?
    Rock
    BTW It looks really good.
    Team Junk
  17. Thanks greatwhite85 thanked for this post
  18. #58
    ST.PETE FL.
    5 Thread(s)
    god damm looks killer, u might want to start a little side business ,im speechless ! GREAT JOB BUDDY!
  19. Thanks greatwhite85 thanked for this post
  20. #59
    Pekin, IL
    Been wondering what it weighs. Have you had a chance to check it?
    Rock
    Team Junk
  21. #60
    Jul 2011
    San Diego
    [QUOTE=rock;2860306]Been wondering what it weighs. Have you had a chance to check it?
    Rock[/QUOTE
    Top cowl-15 lbs
    pan-7 lbs
    front cover-1.6 lbs
    so altogether it is just shy of 24 pounds. Certainly not a lightweight version, I just can't compete with molded plastic. But it's almost 1 1/2 pounds lighter than the old cowl I'm replacing it with and if my calculations are correct that equates to 100 h.p.
  1. Allisonxr2001 rear cowl.. For two seat conversion
    By Phil Conant in forum Misc. Parts and Accessories
    Last Post: 12-14-2015, 07:47 AM
  2. 3 litre alian hood conversion
    By Image 21 in forum Appearance Mods
    Last Post: 04-09-2013, 09:45 AM
  3. Alien Cowl Conversion
    By halveb in forum Technical Discussion
    Last Post: 03-05-2010, 02:09 PM
  4. latest creation 3 litre alien conversion complete
    By Image 21 in forum General Boating Discussion
    Last Post: 01-24-2009, 01:54 PM
