Results 1 to 10 of 10
    Nov 2004
    FORKED RIVER nj
    Motor height laser ltv
    I need advice on motor height and prop for 85 laser ltv any base cavition height ideas have transom wedges and 6 inch set back jack plate Johnson 150 came with merc chopper spins around 5,700 rpm I realize srx would be better boat seems like should go faster but it's hard enough to plane off is there a good starting point?
    three 13' Bullets collecter?
    13' Funcat sold
    12' HydroMate verga Fleet of mini boats
    Laser ltv
    21 checkmate. Vengeance racing
    21 shadow sold
  2. Likes canardnoir liked this post
    CHAIN O LAKES, IL
    Propshaft centerline 1"-2" below pad good start point, 24"-26"chopper or srx 23"-25" both good props depends on the work been done to each...one may be better than the other because of the particular work done to each ...no way to know until u try it.
    u only got 150 hp if its fresh..... Prob more like 140hp at the prop..... Dont expect much more than 65-70mph.
  4. Likes canardnoir liked this post
  5. #3
    Sep 2006
    I have a Charger STV(Canadian build from original molds) which is heavier then an LTV. I am running a 200 2.4 efi with a 5 inch setback. I generally am running prop shaft equal to the bottom of the pad . I may bump it up a bit (no more then an inch above ) but find my boat likes it even. I find trimming down after your going really made the best difference in speed. I just watched the rooster.
    Sep 2006
    Jul 2013
    Sewell, NJ
    Did you ever figure out what needed to be done to help planning better? I'd love to know I'm having the same problem
    Sep 2006
    Drag plate. No longer need to drop the motor on take off.
    Aug 2011
    South Jersey
    I wedged a kick ball inside my manual jack plate... Keeps it from scouping when getting on plane and lessens the plunge some when coming off.
    Jun 2012
    Bainbridge, Ga
    I run mine 1-1/8 above with wedges and no jack plate
    Flint River Mafia
    1983 Laser LTV #007 RIP Lloyd Burns
    1994 Mirage RR "The Purple Drip" SOLD
    2002 Laser LTV "SOLD"
    Apr 2018
    Mid west
    Quote Originally Posted by HPShadow View Post
    Most every single boat out there is going to have usually a lot of slip when planing out with a STOCK chopper prop..
    Every single chopper prop that I have run and enjoyed had been to a prop shop and had cup added to the trailing edge of the blades and I believe a little bit of cup at the tips of the blades as well. These props would LAUNCH the boat out of the water and land on plane with AWESOME acceleration!!
  12. Thanks coffeeguy thanked for this post
    Jul 2002
    If you want haul ass 2” above the bottom. Neutral trim and big wheel.
    TC
  1. engine ride height charger stv(copy org laser ltv)
    By coffeeguy in forum Props, Setup, and Rigging
    Last Post: 09-28-2015, 06:29 PM
  2. propshaft height on Laser
    By hrvx in forum Technical Discussion
    Last Post: 03-06-2010, 06:30 AM
  3. Motor Height Help
    By 21eagle in forum General Boating Discussion
    Last Post: 12-04-2007, 01:55 PM
  4. Motor height
    By ugotmerced in forum Props, Setup, and Rigging
    Last Post: 05-20-2007, 03:22 PM
