Results 1 to 3 of 3
    Feb 2010
    Mount Hope, Ontario
    Oil change interval
    On a small 1996 (?) Mariner 9.9 hp 4 stroke, how often does one change the oil? There is no filter.
    Canada, East!
    50 hrs or once a season.
    Pretty sure there is a oil filter, went and checked: http://www.crowleymarine.com/mercury...cfm?mdl=0QAN4Q
    # 7
    pointer
    Feb 2010
    Mount Hope, Ontario
    Thanks for the info, I will double check.
  1. IO impeller pump replacement interval?
    By Euroski in forum Technical Discussion
    Last Post: 05-22-2012, 11:04 PM
  2. prop change ? or gearcase change.
    By jlay in forum Props, Setup, and Rigging
    Last Post: 11-13-2010, 09:36 PM
  3. You wanted "CHANGE", you got change....for the worse
    By 302w in forum The Scream And Fly Lounge
    Last Post: 01-15-2009, 08:16 AM
  4. How often to you change your LU oil?
    By imq707s in forum Technical Discussion
    Last Post: 05-07-2004, 04:53 PM
